Very true...but at least I'd imagine they'd be a fraction of the cost of even one of those cascades.
How did it turn out? Can't see any updates on your scores, yet? :)
I see ;)Quote:
Originally Posted by pc ice
When you grab some time, knock up a single stage ;)
so power problems were greater than first anticipated?
Lets hope for the best
First some nice pictures of PC ICE cascade then plan to take over the ORB but then nothing?
OPPAINTER, Any update or info what happened? Atleast the cooling looks impressive.
Or did poor Charlie lose all his money? :D
LinkQuote:
Originally Posted by charlie
Sorry to disapoint you for not breaking some records but I'm haveing problems with Vid cards there Sampsa. Waiting on new 6800 Ultra.Quote:
Originally Posted by Sampsa
Then again I did beat YOU, you smart arse:D so not all that bad:D
OPP
http://www.xtremesystems.org/forums/...id=31903&stc=1
Shame that you just cant get the cards that will perform...
Seems that the FX is doing very well though ;)
Only 22 points behind...
*crosses fingers for OPP to get some decent cards* :D
165 points higher at identical card clocks and only 90mhz. more on cpu. Nice score OPP! :toast:
But check out that OPPs score is done with 76.10, it will sure give some boost vs 71.89. But the score is really nice :DQuote:
Originally Posted by harleybro
and the score is not approved by FM, nothing to brag about... :)
:DQuote:
Originally Posted by OPPAINTER
I wonder why did you run with the non-approved 76.10 drivers?
Anyway, good luck with your efforts. Me & Kamu won't propably bench with 6800 Ultras anymore so 14436 will be our final score with them.
Great scorage OPP. :toast:
So one card holdin you back? I think its the same here, I'm runnin 1 prereleased Asus and 1 aftermarket Asus and the aftermarket runs at a higher core than the preleased without artifacts. Gotta get myself another proper Asus :)
LOL....Hope you can get another card to match your good one OPPQuote:
Great job :toast:
Lardarse,Quote:
Originally Posted by LardArse
You should try that driver I used. You could probably break 15k with it.
Thanks to MrIcee and his all day of driver testing:D
And Sampsa, now my bad card is completly useless, artifacts. I may never get an offical 6800 Ultra score up at this rate.
OPP
Ok, I wonder where those artifacts came, physical damage on card? Well, maybe it's time to change focus to next-generation cards? :)Quote:
I don't know what happened, all I did was switch the cards around. I put the not so good card on my Slot1 cascade and the good card on the Slot2 cascade. I never even got to do any runs. The not so good card was messed up the mintue I fired it up.Quote:
OPP
Sounds strange, we managed to ruin one card with DFI mobo thanks to lower PCIe connectors compared to Asus A8N-SLI DLX. LN2 container was binding the card so it was only half way installed -> RIP :(Quote:
Thx for the headsup OPP. I'll be sure to try them if I can tonite if not then will have to wait a while.
Sorry to hear about your card, but you were going to replace it anyways right?
