Why in hell would you wan't to run it stock, seems like refusing a bonus from the boss to me :stick: :DQuote:
my X800 XL is water cooled... 470 core no vmods.. my last one didnt respond to vmods... wouldnt boot.. then i shorted 2 resistors with multimeter probe .. sparks followed then card death... anyone actually vmodded a connect3d sucesfully yet?????
Ouch, sorry to hear about the bad luck.. Exactly why I do not trust my self with a soldering iron on a $250+ piece of hardware.... Hope you get it figured out, Im sure there is someone here that has volt modded that particular card...Quote:
Originally Posted by pancake
Good luck
Yeah, sorryQuote:
Originally Posted by reject
Any mods to connect X800XL? Pancake did u find?
no . board looks the same though so ill give it another try when i got time
is it true that X800XL doesnt have PS 3.0 ?
Originally Posted by TEDY
Yes, no ATI card has PS 3.0 yet.
grrrrrrrrrrrrrrr.......will they enable them with new drivers or is it impossible on X800XL ?
well i'm selling my XFX 6600GT PCIE 128MB and getting POWERCOLOR X800XL...Am i mad ?
HI
I think it´s impossible! to active/change PS 2.0 to 3.0 with new Drivers.
...ok --->I gave My x800xl-GPU 1,72Volt but I cant´t run without artefacts over 509 GPU :( and I won´t use mor Volts! but the temps are very well :)
29°C Idle and 36-37°C under pressure and inviroment max. @40°C
I think my GPU is not soo good :(
ok regards Fire113.
As fire113 said, enabling them via drivers won't be possible.Quote:
I'll get myself a x800xl as soon as Venice will be available to me so i won't call you mad on this one :D
Hey Eradicator,Quote:
Originally Posted by Eradicator
I wouldnt worry too much abt the voltage, my 492 runs need 1.75v to run.
:eek:
The temps are also good, with my fans on full whack the core doesnt go over 40C. I think the core has run out of steam, from 475mhz onwards the increase in voltage needed to run a few more mhz is alot higher than at lower mhz.
I also dont get hardlocks but i get a distorted screen, like back in the day with the 9500's which had bad pipes, i get like checkerboard effect and need to reboot.
Dont know if anybody else is experiencing this, I want to know if anybody has done the overcurrent protection mod on the GPU, maybe this is my problem???
Oh anybody know if their is a way to post score without having 3dmark01 installed? I am not on the net and want to upload a 32k+ score. I tried putting 3dmark01 on a disk which and running from this, which works at home, but the library computers do not have dx8.1 so the app wont load
:rolleyes:
last question :
does X800XL have temp. monitoring etc ? :=)
Yup through rivatuner and atitoolQuote:
coool :P
MY NEW GFX :)
any ideas which cooler to get ? :=)
http://img226.echo.cx/img226/4195/x800xl15ow.jpg
http://img226.echo.cx/img226/11/x800xl36ht.jpg
http://img226.echo.cx/img226/9536/x800xl47xc.jpg
http://img226.echo.cx/img226/2007/x800xl56vs.jpg
as you can see it doesnt have even power connector :(Quote:
So how does it performs?Quote:
don't have it pyschically yet...on wednesday-thursday.....hehe....friend bought it for me in austria etc....
hi guys
...can´t believe what I saw ---> My ram is running @635 :) but I can´t run GPU over 509 ;(
cu fire113.
Don't worry about it, a LOT of non power connector/2.0nS cards FLY!! Mine does like 550/615...Quote:
which cooler you suggest charlie ? :)
yea charlie. What should I do to cool my BBA x800xl. NV Silencer 5 or save for water. Ah nm, water it is :P
AC Silencer5 is good, so is the little Zalman...Quote:
Do the Vmod, up to about 1.5v on air... should be good for 460/575...maybe better ;)
C
I second the Zalman, it only dropped my temps about 5-7 degrees, but the temps were very low(36 idle, 65 load) to start with. Now they're around 34 idle, 59 load after the volt mod. The move to decent ramsinks seems to have given me about 25 Mhz more on the ram, as I can go to about 605 without artifacts, and before was getting about 580 before the card hard locked.Quote:
Originally Posted by charlie
