Originally posted by WoodyNY
Hello everyone,
I do not see any additional options (as I hoped for) under Display Settings/Advanced (like Core Speed) so I do not know if this was actually flashed to be and perform like a true Radeon 9800 XT or its still operating as as Radeon 9800 Pro with a different BIOS string.
Are there any utilities that I can download and test out the performance and internal information for the Radeon (like Memory Clock, Card ID, Core Clock, Memory, etc).
The difference (if I read it correctly) should be:
9800 Pro: Core Clock: 378Mhz - Memory Clock: 338MHz
9800 XT: Core Clock: 412Mhz - Memory Clock: 365Mhz
BTW: the Bios title for 9800 Pro should have read: "R360 Hynix DDR BIOS W THERMAL CONTROL - P/N 113-A18805-105 (using Hynix 2.5)" and the Bios title for 9800 XT should read "RADEON 9800 113-A18807-100 BIOS" (not sure what memory). I do not know how this relates to DDR2 memory.
If I can find any utilities for testing the above information I will post my findings here ASAP.
Thanks to the original poster for finding this and starting the thread.
I am running the Find Max Core/Find Max Memory functions tonight and will post any new findings.
do i get this right. your card still shows as 9800pro? if so, did you remove the old display drivers (completely)?. could help. i removed my complete cats + cp and reinstalled the latest ones at the time 4.2 or 4.3 (dunno). with cp4.2 came the overdrive tab - and as you flashed it to 9800 xt, it should give you the temp-diagnosis and the enable overdrive thing, which basically is crap as it will not go much higher than default (418 core, irrc). so once you flashed you should be reading 9800xt in the control panel.
