how would bolt thru heatsinks work? what would you do about the four screws that hold the metal socket piece in place?
edit: i can't find any bolt thru heatsinks for this platform... where are they?
Thanks. Worked nicely, apart from me drilling the original pilot holes in the wrong place - d'oh!
http://www.abload.de/img/dscf2004auxp.jpg
Hi there,
i have bought four thermal take A one heatsinks and i have broken plastic hintches and mount them normally.Dont drill the board,later today i will post pics of the quad and the Arima nm model.
give me some time to get back home.
My 8347s should be waiting for me by the time I get home (two anyway). So I'll know tonight if the setup fires up. Maybe I'll have some WCG units rolling in by this time tomorrow.
i hope so. i'm getting inpatient to get this up and rolling.. points are a wastin'
Nothing going post wise, either cpu in socket 1 or any combination of ram. Using a PCP&C 610 silencer and it has the needed connections. Getting fans but no beeps and it responds to power down presses. Anyone know a trick to these guys?
FILE NOT FOUND, where are you? :)
Make sure cpu0 is filled and cpu0_dimm1-4 is filled. Try just that combo
Edit: if that doesn't work I think you're SOL. Everything I can find on that board lists compatibility with 2000 series opterons only
Manual calls for starting on slot 7-8. May not be labeled the same as the quad board. Not even getting a beep code with no ram installed though so not thinking RAM for now.
Keep trying I guess
I haven't read through this whole thread yet and was wondering, how many PPD (WCG points)are you looking at with the 4 x 8347's. :shrug:
30kish.
Any luck mojo?
Nah, I've used up my testing trick pool. I bought a 2212 to test with, as I'm betting on CPU compatability issues at this point. If I'm limited to 2000 series CPUs I'll just grab a pair of 23xx quads when I see a good deal and save the 8347s for a quad board. So unless someone has some tips I'll know more in a few days. Playing with random server parts sure is fun, been a long time since I've tried to put together something I wasn't sure was going to work or not.
i was going to suggest that next. i read in an earlier thread that if you update to the v1.8 bios it should allow 8000 series quads to work. might try that
Nice, I was hoping that'd be the case. The 8000 quads are much easier to find cheap.
yeah especially since i already bought four of them lol
Mojo,
There should be no difference between 2xxx and 8xxx, they all came out at the same time and a board which will run one will run the other. Are you running the onboard VGA or an external card? There's a jumper to switch between the two, check it's in the right place...
Also check the manual to see if there's any jumpers that govern booting to a serial console (which you want to disable) or other such oddities
Using onboard, only option unless I crack a pcie slot open. I've been over everything obvious manual wise, switched the onboard vga off then back on, reset BIOS etc. I've got a deffective board, it doesn't like the CPUs or there is some oddball thing I'll never spot on my own. CPU is the only thing I can check for sure at this point so headed that direction.
What's the specs on your RAM?
they're ddr2 ecc reg pc2-4200. we have the same ramz
