Your currently at 13th - with your current setup you don't think you could get at least top ten - maybe top five!
EDIT - I've had first place now 4 times!
The longest I've stayed there is 54 hours!
1 or none. :D:rofl:
If you remember your log in - you should at least go in and give your 13th a title - http://www.futuremark.com/community/...pcmarkvantage/
done :up:
ok,heres my entry into the i7 section.i hope it's ok that i'm only running 4GB.
i dont have a triple channel kit at the moment,but i'm trying to rectify this.
as for cooling,i've got my cpu under water plus AC to keep the loop extra cool:up:
□□MB□□-Gigabyte X58A-UD3R
□□CPU□□-i7-920 #3845B027
□□MEM□□-G.Skill DDR3-2200 cl7
http://valid.canardpc.com/show_oc.php?id=1155708
21x215@4515 w/1.37v w/HT on DDR3-1720 8-8-8-21 1t
LinX 20 runs completed-Vista x64
http://i42.tinypic.com/o044ms.jpg
Prime95 Blend 2hrs running-XP x86
http://i43.tinypic.com/2mzll74.jpg
Prime95 Blend 2hrs stopped-XP x86
http://i39.tinypic.com/awyjux.jpg
Managed another run out of my Gulftown 3003B287, HT on. Gflops a bit low but I cannot think why.
http://img291.imageshack.us/img291/3...pture30.th.png
Much Congrats Mr's Radaja and Newhit - nice runs!
Newhit - I see you're getting aggressive with the temps.
First time I got a i7 prime stabe 8hrs at 4ghz I was at 97C.
I went on to set a pcmv WR with that proc- your fine!
It's weird really. The temps fluctuate about the late fifties to nudging seventy but when I come back to check that all is well I find 80 to 91 degrees logged on 'Real Temp' but if I watch LinX testing for a while there is only 60 to 70 degrees fluctuations........weird :shrug:
SteveRo,thanks
Kitfit1
i975
4840mhz
1.552Vcore bios set with Vdroop enabled =1.487Vcore under load
Batch number is unknown (have never looked :) )
Evga E760
6gb G-Skill Perfect Storm
Asus 5970
Custom built SS cooling.
http://s5.tinypic.com/aeqqvq_th.jpg
Yes i did build it myself.
I will post a build log in the phase section at some point.
But you can have a look at This thread at Benchtec Uk.
It shows the whole build from start to finish, including load temps at 1.6Vcore running the 975.
I played a little tonight
http://i162.photobucket.com/albums/t...ytt/lynx-1.png
kitfit1,thats an awesome OC.i wish i had a single stage unit or was able to build one like you.
BobyTT,very nice vcore for you 980x's OC.these 980's look like great cpu's.
Good job, guys! It's great to see Gulftowns almost hitting 4800! :D
kitfit1 - your setup and skills are crazy, respect! :up:
TY , i am impressed by Gulftown so far...
Thanks radaja :)
Thanks newhit, i wasn't aware that the EVGA had gone away :D
Thanks zalbard, if you think that clock is crazy, you may not want to see the clock i'm working on at the moment :eek:
BobbyTT - very nice!
Nice low vcore too!
http://img521.imageshack.us/img521/2...inglinx.th.png
#3912B185
4.51GHz i7 920 D0 @ 1.424v
Asus P6X58D @ 215MHz BCLK
6GB Corsair XMS3 1333MHz @ ~1750MHz 8-8-8-20 @ 1.5v
3x Asus Dark Knight 9800GTX+ @ 740/2000/2412 @ stock volts
36GB Raptor
Corsair HX850 PSU
Swiftech GTZ Waterblock (Pressure modded, dropped temps by 6c)
1x Thermochill P120.3 w/ 6x Sharkoon Silent Eagle 2000 120mm in push/pull (being upgraded to two of these daisy chained next week)
Swiftech MCP655-B Pump @ ~4400rpm
XSPC Bay Resevoir
Feser One + Deionised water
1x Sharkoon Silent Eagle 2000 120mm on CPU PWM
BobyTT: Can you tell us your batch # please? Also, that's a very nice vcore for 4.7 I'd love to see a bios template for that oc?
http://i162.photobucket.com/albums/t...h_IMG_8448.jpg
For the BIOS template i have to go home and see...
I have a feeling 3003B320 is the new golden batch.
I've only seen two of these, one is yours, and the other one passed AM3 at higher frequency than most chips can post at... See the list here.
