50% more? Should be a bit more than that since this should be ~90-105% of a GTX295 (or >=2x4890). If we get similar scaling as now it would be 60-70% faster at least.
I guess ^this^ is just because of the one fake dualcore RV870 die shot that Chiphell barfed upon us.
Modified specs about the HD 5870 (core clock , memory clock & compute power)
http://i30.tinypic.com/maw86p.jpg
source: http://www.arabhardware.net/forum/sh...d.php?t=133519
are you going to call gt200 a quad core then ? :rofl:
http://www.nordichardware.com/image3.php?id=5155
Example of such reputable sources?
Chiphell? Random forum posts?
Hardware.info? (<- the same site that is known to post whatever they see on forums, eg. once they posted my own ramblings/speculation on RV790...)
Theo's brightside?
No. I do not.Quote:
At least now you agree in principal that it is a 'dual core' gpu.
Nice attitude, btw.
:up:
I hope the 2 intake vents cool the card adequately.
^Uh?
There's one big intake - the face of the fan. Just like on previous Radeon coolers.
Techincally no
The Cypress isn't two interlinked GPU's cores
Yes they did double SIMD cores,but it has still only single command processor,single thead processor and a single crossbar, the important bits of the GPU core.
The SIMD cores are modular,you can add or take away as many as you need.
The 4870
http://www.overclock.net/attachments...770archlx4.gif
The fact that PEG plugs are on the side doesn't mean the holes are intakes.
:stick:
http://news.ati-forum.de/images/stor...ssslides/2.jpg
So the specs are all but confirmed...
Core clock is indeed 850 MHz. Strangely, they made no mention of it being 256-bit... maybe ATI pulled a fast one? :p:
Why would they direct air out the back? I'd want every bit of air a small blower fan can push going over the core heatsink of my 2.1b transistor chip...
i really think they should make the cards 1-2 cm taller (or just the heatsink shroud), the power plugs will already extend up, might as well give themselves more room to squeeze in a larger quieter fan.
Is it more, or are not enough people questioning the validity of the crysis benchmark, when there isn't even a damn screenshot.
given that this thing barely uses any power at idol, I shouldn't imagine the fan needs to be very fast at all. When your gaming the noise of the game should drown out the noise from the fan anyway, Unless your one of those who like to stick massive full size atx cases on their desk???
Personally I prefer my case to be concealed under my diy computer desk.
