Ah ยงยงยงยง...is it still working on a diff mobo or the hd is wasted??..and is this a bios prob or ahardware prob?
i think he means on any infinity. i have the exact same hdd with teh exact same problem.... im at a loss as for what to do. only thing i can think of is wait till we get a new bios.
can i get a repost of the link to the lis of infinity bios's. i lost the page.
me too! I practically begged him to come back. :(Quote:
Originally posted by Walrusbonzo
I've sent him a PM on AMDMB, fingers crossed.
i still am confused about what happened to make OSKAR leave...and on top of that, ive never heard of someone getting mad and bein like "Im takin my toys and going home!!" lol, someone musta said something pretty bad to make someone leave a forum.
He was here for only a few posts, had done some great work with the BIOS, let us know and wasn't made to feel welcome.
It happens, no hard feelings to anyone involved, OSKAR included.
Sure wish he'd hang out here though :(
Eclypse had told him off and told him to leave. So, in a gentlemen's fashion, he did, just like that.
wow, gg eclypse
this would be a fantastic time to get back on subject.
how bout another post of that list of bioses!
So the system won't recognize the Western Digital discs at all??If you use a WD disc as secondary,will it recognize it then?
Beta BIOS'?
here:
NF2 Ultra B 12-10: http://myweb.hinet.net/home8/oskarwu/N24LDC10.zip
Infinity: http 12-10: http://myweb.hinet.net/home8/oskarwu/N24IDC10.zip
NF2 Ultra B 12-18: http://myweb.hinet.net/home8/oskarwu...s/N24LDC18.zip
Infinity 12-18: http://myweb.hinet.net/home8/oskarwu...s/N24IDC18.zip
Go, go OSKAR_WU!
He has 2 beta's out!?!? Which one to use then? 12/10 or 12/18...or are you going to give me the try both and use what works best answer? :) ;)
this is a good question.. tomorow ill try this in the morning. ill report what i find.Quote:
If you have WD disk problems like me..try to test this..
Oskars bios detected the disk wrong(CHS is defualt in bios). i change it (detected it in the bios after the flash) . and know it works fine . Auto = LRG = works fine
You need to change it to Auto instead of CHS! . After the flash it are @CHS as default
I had a Thread in Amdmb forum about this problem somethimes ago.
both are good. i thnk the 18 is best though. i know OCZ likes 12-18 bios best.Quote:
Actually OSKAR has more than two betas out. Those are the most recent.
OSKAR has posted over at AMDmb.com ... they cant duplicate the HD problem... he wants help to try and dup it so he can fixit.
nieuw beta bios DFI rev. B:
12/31 BIOS update as follows :
Key Change of 12-31 BIOS Since The 12-18 BIOS(12-18 BIOS is previous beta BIOS)
1 . Add Command Per Clock Option in Advanced ChipSet Feature BIOS menu
Choose Disabled will improve Double Side DRAM Overclocking Ability
2 . Fix 12-18 BIOS 8X , 8.5X fail to boot when CPU interface is Aggressive
and FSB >= 200 MHz
3 . Change The topology of DIMM Driving and Strength
get it here: -> edit, go the link at the bottom of this box.
link: http://www.ocworkbench.com/ocwb/ulti...;f=34;t=000021
Good luck! No testing here, rev. B is dead :(.
12/31 is the newest...will have to try that one...Still using stock bios...
i PM'ed hm and were tryin to figure it out.Quote:
it really is a WEIRD problem. and it seems to be very wide spread. so he will have plenty of info to help solve this.
im finally back on my infinity after my wd hdds corrupted and/or woudlnt work. OC time commin!
How are your results with the new bios spork?
yes, if you use it as a secondary, and do not load an OS on to it and use it as the boot drive, then you should be ok.Quote:
not too shabby aye?:slobber:
its not stable there AFAIK, it crashed at 268.
i think its mearly ram holding me back. 258 @ 2-2-2-5 with only 3.3 volts is really good.. but pushing the limit. im gunna do teh voltmod on teh ram in about an hour i think so ill have like 3.5vdimm to play with. hopfully i can get 270 stable then.:smileysex
well my boards dead.
tried the vdimm mod and the resistor popped off. LOL
be careful when doing this.
ill see if someone with better equipment can fix it.
Poor board.... poor memory inall too thats just cruel :o
im wondering what would happen if i ran it with no resistor there... might it work? or would it put like 3billion volts into me ram?
