Could someone tell me what the max Vcore is on the UT P45-T2RS?
In the Bios the max is 1,6V, i dont know if the special add works with this Vcore setting, when it works you can give more Vcore than 1,6V over the special add option.
How much more?
Cause 1.6v isn't enough for me anymore :p:
The voltage go up to 1,6V. The Special Add go up to 130%. When the Special Add work with this high Vcore you can give your CPU 2.08Vcore :eek:.
1,6 : 100 = 0.016 x 130 = 2,08V
I dont test it with my good Q9550 :cool:
That sounds awesome, I might look into this board more, the only thing is I can't seem to find one in Australia or on Ebay :(
I think this Shop ships arraund the world -> http://www.motherboardpro.com/
Edit: I just looked in the checkout and it only says Canada and USA :(
i killed one of my most highclocker E8400 last feb.
right now I'm having problem with my DFI Lanparty UT P45 T3RS.
i couldn't enter bios in any way.
i already did all the methods below but the result is always the same.
clearcmos & remove battery for 8hrs. no power connected to the mainboard.
replace psu & video card, proc & cpu cooler.
the only thing i've never did is to replace the memory.
before my e8400 died i already did some occt 2hrs mix stability testing with that board & my 3gb kit team xtreem ddr3 1866 in dual channel mode.
it run stable with my settings.
then after my e8400 died, i tried to borrow some procs on my cousin. E5200 & E2140
E5200 run's fine on my mobo that time, but when i tried to put e2140 on my mobo i started experiencing the bios problem.
i can boot to windows without any problem.
i already did flashing the board on windows & dos mode several times & the result are always the same. can't enter bios.
the last test i did is memtest for dos. 3 rounds of standard test without any error.
please let me know if you have any solution to this problem.
thanks in advance
I love this Motherboard!
http://valid.canardpc.com/cache/banner/524343.png
Any one of you can run with FSB, lets say... 640-650MHz?
DK plus is really great, but I don't saw any superb scores on UT :(
anyone get this thing higher than 512. as high as i can go is 512x8 and then there seems to be a wall that wont let the board even post.
i tried using x7 and it wouldnt go higher either. this is completely stable in OCCT
i plan on watercooling this board in the near future just gotta pick out the components
whats the max people have gotten this on air.
the CPU-Z validation for 512 in in my sig
this is the 510 screenshot but i did it for 512 too
http://i60.photobucket.com/albums/h5...3h56-VCore.png
Ok guys I have problem with my Mobo.My vdrop is quite high 0.057v - vdrop is disable in BIOS.
I have very nice chip Q822A462 and I can't reach 4.5 GHz with 1.375v set in BIOS stable.
My settings:
450x10
1.375v BIOS (1.328v OS)
VTT 1.2v
NB 1.2v
GTL 0.625 each
DDR/CPU 1:1 (tried 5:6)
DDR 2.19v
PLL 1.55v
I notice when I set NB higher than 1.24v I have nothin on screen and I can't boot to windows.
Even 4.8 GHz with 1.475 I can boot to windows.
I can do 4 GHz with 1.18v easy but nothing more stable.
Maybe I shoul set additional VID in BIOS or something like that - anybody can help please.
My Mobo is DFI P45 UT T2RS ofcourse.
I bought this board and im interested in the best bios for this board
ok just installed the newest bios (not beta). I like the board already, without any overclocking done :)
anyway 1 small drawback tough. I put my vga in the second slot as im running a ram cooler and therefor the vga cant fit in the first slot. I noticed that my vga was running at 8x instead on 16x. Is it possible to run 16x in the second slot?
i hope we can get this thread running again :) Anyway ill probably will post my overclocking tries in here :)
played a little with the board as i didnt had much time. It clockes my e8500 a lot better then my maximus II formula, as it needs less voltage, but i couldnt get my ram to the desired frequentie quick. Im running 4x1gb d9gmh and i got them to 1200mhz pretty easy on the maxiums but i couldnt get the DFI stable at 1100mhz (only thing i tried).
Anybody has some tips to get the ram clocking on this board?
Atm im not at my pc so i cant post a bios rundown, ill do this when im back at my pc
kamieldehond, I just picked this board up a couple days ago. My work schedule is not good during the summer, so I probably won't have much tweak time until late August, but I'm also interested in what this board can do. I had the p35-t2r watercooled with a q6600 and waterblocks on the mosfets and nb. I did pretty good with 4x1gb sticks. If I remember correctly, I had crucial 8500 tracers @ 450fsb, 1200ram 2.3v. I would hope this board can do that also.
I am curious how this board does with q9550/q9650s. Everybody claims the p45-ud3p is great with quads (500+ fsb), but I haven't heard how this board does. Anyone had any luck? Also curious how it does with the new low voltage 2gb ram modules like the ocz blade series.
getting some wierd stuff from this mobo. the error codes i get:
75 when it just hangs in bios
7F when loaded the bios defaults are loaded
FF when its booted in to windows (dont know if this is normal)
anyway when i look up the last 2 error codes it says i should rma the board, or do i just not read the error code list right?
*edit
googled a little more and found out that FF is normal when you boot to windows so no problem there :)
>CPU Feature:
Thermal Management Control.......... - Enabled
PPM(EIST) Mode...................... - Disabled
Limit CPUID MaxVal.................. - Disabled
CIE Function........................ - Disabled
Execute Disable Bit................. - Disabled
Virtualization Technology........... - Disabled
Core Multi-Processing............... - Enabled
>DRAM Timing:
Enhance Data transmitting........... - Auto
Enhance Addressing.................. - Auto
T2 Dispatch......................... - Disabled
>Clock Setting Fine Delay Press Enter:
DLL And RCOMP Settings.............. - Auto
Ch1 Dram Defaul Skew................ - Model 0
Ch2 Dram Defaul Skew................ - Model 0
RCOMP Settings...................... - Model 2
Fine Delay Step Degree.............. - 70ps
Ch1 Clock Crossing Setting.......... - Auto
DIMM1 Clock Fine Delay.............. - Current[1346ps]
DIMM2 Clock Fine Delay.............. - Current[1346ps]
Ch1 Control0 Fine Delay............. - Current[166ps]
Ch1 Control1 Fine Delay............. - Current[166ps]
Ch1 Control2 Fine Delay............. - Current[124ps]
Ch1 Control3 Fine Delay............. - Current[110ps]
Ch1 Command Fine Delay.............. - Current[262ps]
Ch2 Clock Crossing Setting.......... - Auto
DIMM3 Clock Fine Delay.............. - Current[1346ps]
DIMM4 Clock Fine Delay.............. - Current[1346ps]
Ch2 Control0 Fine Delay............. - Current[14ps]
Ch2 Control1 Fine Delay............. - Current[56ps]
Ch2 Control2 Fine Delay............. - Current[0ps]
Ch2 Control3 Fine Delay............. - Current[0ps]
Ch2 Command Fine Delay.............. - Current[110ps]
Ch1 Ch2 Common Clock Setting........ - Auto
Ch1 RDCAS GNT-Chip Delay............ - Auto
Ch1 WRCAS GNT-Chip Delay............ - Auto
Ch1 Command To CS Delay............. - Auto
Ch2 RDCAS GNT-Chip Delay............ - Auto
Ch2 WRCAS GNT-Chip Delay............ - Auto
Ch2 Command To CS Delay............. - Auto
Flex Memory Mode..................... - Auto
CAS Latency Time (tCL)............... - 5
RAS# to CAS# Delay (tRCD)............ - 5
RAS# Precharge (tRP)................. - 5
Precharge Delay (tRAS)............... - 15
All Precharge to Act................. - Auto
REF to ACT Delay (tRFC).............. - Auto
Performance Level.................... - Auto
>Read delay phase adjust Press Enter:
Channel 1 Phase 0 Pull-In........... - Auto
Channel 1 Phase 1 Pull-In........... - Auto
Channel 1 Phase 2 Pull-In........... - Auto
Channel 1 Phase 3 Pull-In........... - Auto
Channel 1 Phase 4 Pull-In........... - Auto
Channel 2 Phase 0 Pull-In........... - Auto
Channel 2 Phase 1 Pull-In........... - Auto
Channel 2 Phase 2 Pull-In........... - Auto
Channel 2 Phase 3 Pull-In........... - Auto
Channel 2 Phase 4 Pull-In........... - Auto
Write to PRE Delay (tWR)............ - Auto
Rank Write to Read (tWTR)........... - Auto
ACT to ACT Delay (tRRD)............. - Auto
Read to Write Delay (tRDWR)......... - Auto
Ranks Write to Write (tWRWR)........ - Auto
Ranks Read to Read (tRDRD).......... - Auto
Ranks Write to Read (tWRRD)......... - Auto
ALL PRE to Refresh.................. - Auto
>Voltage Settings:
CPU VID Control..................... - 1.36250V
CPU VID Special Add................. - Enabled
CPU VID Special Add................. - Auto
DRAM Voltage Control................ - 2.21v
SB Core/CPU PLL Voltage............. - 1.55v
NB Core Voltage..................... - 1.408v
CPU VTT Voltage..................... - 1.303v
Vcore Droop Control................. - Disabled
Clockgen Voltage Control............ - 3.45v
GTL+ Buffer Strength................ - Strong
CPU GTL 0 REF Volt.................. - 0.6250
CPU GTL 2 REF Volt.................. - 0.6250
CPU GTL 1 REF Volt.................. - 0.6250
CPU GTL 3 REF Volt.................. - 0.6250
North Bridge GTL 0 REF Volt......... - 0.6250
North Bridge GTL 1 REF Volt......... - 0.6250
FSB Vref............................ - Auto
Genie BIOS Settings:
Exist Setup Shutdown................ - Mode 2
Exist Shutdown After AC loss........ - Enabled
AC Shutdown Free.................... - Enabled
O.C Clock Fail Retry Counter........ - 1
O.C Clock Fail CMOS Reloaded........ - Disabled
CPU Clock Ratio..................... - 9.5
Target CPU Clock.................... - 4275MHz
CPU Clock........................... - 450
Boot Up Clock....................... - Auto
CPU Clock Amplitude................. - 800mV
CPU Clock0 Skew..................... - 0ps
CPU Clock1 Skew..................... - 0ps
DRAM Speed.......................... - 400/800
Target DRAM Speed................... - 900MHz
PCIE Clock.......................... - 100mhz
PCIE Slot Config.................... - 1x 1x
CPU Spread Spectrum................. - Disabled
PCIE Spread Spectrum................ - Disabled__________________
These are my bios settings. I dotn have much trouble getting the cpu up and running as fast as i want, but i cant get the memory as fast as i want. I know i can run it 1200MHz at 2.2V as i could on my old board, but the DFI keeps crapping out even at 1100MHz.
I must atmid that i dont know much about overclocking memory, so i probably have overlooked a setting that is holding me back, but i got nu idee what setting :(
Aybody that can push me in the right derection?
Ok this is funny. I had lots of problems getting my memory stable at high frequenties (using memtest86+). So i was upping NB voltage, but this wasnt helping. So I upped the NB to 1.5V and notived i got more errors in memtest. So decreasing NB voltage to 1.35 volts did the trick for me to get more stability.
fsb: 575
divider: 333/667
CAS: 6 - 5 - 5 - 15
fsb 575 1h orthos stable :up:
more to come :yepp:
http://i26.tinypic.com/vp9gjl.jpg
Well done kamie. Those are very nice voltages for 575FSB.
I'm stuck at 520FSB....I fail Prime95 640k thread (I run a full test, find where a specific failure is, and see if I can pass just that thread multiple times) after 45 minutes no matter what voltages I use. 520FSB seems to be stable at 1.19v VTT and 1.29v FSB for me.
Can I see your 575FSB full settings? Thanks. :up:
Have a look at these settings. Although they are for 563fsb, they should give you a good idea as to what you may need to change.
