the ICs on this ram is elpida too.. the DIMM is single-sided (ICs only on one side)
:up:
I have partnumber KVR400D2D8R3/1G .
No 'I' mentioned ...
Also Elpida chips here , AGBG-6E-E
16€ ??
I've paid 29€ ... :shakes: (also bought 1 stick for now)
Yeah well.. w/o taxes ;)
But still :D
Well, I would imagine raising the fsb would also raise the ram clocks, but I guess that wouldn't be a bad thing :)
Do you happen to know where the FS_A and FS_B pins lead to, somewhere on the chipset I assume?
How sure are you that it's a clockgen just for the pci-e?
I just bring this up because on the s771 board I just received it has at least three clock chips, although two are real clock generators, while the other is a buffer for the I/O slots.
Okay, the only reason I bring up it being a buffer is it needs a clock source, which I presume comes from the main pll (which has its SRC output at the desired 100MHz). As a buffer all it's doing is taking the input clock and outputting it at either the same freq or freq/2, just buffered of course so that it has the drive strength/fanout capabilities and what not.
But yeah, I guess I didn't think about it going straight to the BSEL pins, I'm relatively new to this Intel stuff :)
To make sure they're directly connected you could just check with a multimeter in continuity mode.
Though haven't the BSEL mods been tried in the past without success? Just curious what could potentially keep it from taking effect.
very nice gongo
could anybody tell me what the best graphics card i could put into one of these would be, ive only got the pci-x slot, and the pcie 8 or whatever it is
http://www.newegg.com/Product/Produc...82E16814161079
or:
Take an xacto knife, heat blade and cut out the back of the pci-e x8 slot and slam a regular vid card in there.
Will work fine with an X8 signal
That is exactly what I was planning as well. Many motherboards with an extra PCIe 16x slot are made that way as well, with the only difference there being the physical x16 slot available. The only thing I am worried about is the amount of current the x8 slot can deliver. I wouldn't want to throw a mid-end GPU in there (IE 4650/9500GT) since it uses nearly all the power a x16 slot supply. That would be way over the specs of a x8 slot. I'd only use low-end cards and high-end cards with an extra power connector.
maybe..But consider this;
On the supermicro X6xxx series they have 2X16 slots and the second carries a x4 signal but works fine with a vid card so I'm assuming that this x8 slot will also.
The funny thing is that in the bios there is the choice for pci-e or onboard vid.
That was a pleasant surprise that I didn't expect to see.
Yes I know, but because it's a physical x16 slot it can deliver the current of a x16 slot, yet it only has the usable lanes of a x4 slot. That is what I am worried about. Data is not an issue here, it's the amount of current that can go through a x8 slot rather then a x16 slot :)
I am going to use the onboard video.
This is the only board I have with integrated video, so I'll try that.
Sossaman is not really a gaming platform is it?
would i see any bottlenecks if i threw a gtx 280/9800gx2 in there? p.s. posting from a psp is a real pita
