aLL i can say is that I would not let a machine run at over 75C no matter what.
Something is wrong or your in a 80F room and if thats the case, get some AC in there.
So you are getting 68c real with all 8 cores at 100% and only after weeks 24/7 @ 100%??? :shocked:
My heatsinks are cold - not even warm to the touch after 30 mins of prime95 with the temps saying what they are...how weird. They hit 105c in CT I saw it...but I also kept feeling the HS's to see if they were warm.
Naw the room is around 65-70F. I dunno what the deal is. My case is open and the metal of the case is cool to the touch. The only thing even slightly warm is a single 3870 (after benchmarking) and the ram and the NB, but not even hot, just a bit warm.
Yeah the fans hit full rpm at I think 55c set in the bios. So basically anytime I push em past 50% load. Soon as I stop the benchmark they quickly, quickly go back down to idle temps, so I know the heatsinks are making contact.
I guess I will try re-seating em with some AS 5. They are using the stock thermal pads still and I've remounted em at least 20 times but making sure I mount the right heatsink back to the right cpu and in the right direction. UGH.
It's ok I guess, I have a new tube of AS 5 and some isopropyl alcohol handy so I guess it's worth a shot. Y'all think I should run it for a day, let it cool for a day, then prime95 to let the paste burn/cool or just go for it?
The fans dropping in speed fast doesnt mean the heatsinks are making proper contact.
It is an indicator that the IHS is not touching the cpu cores or the heatsink properly.
This is because heatsinks do not cool down immediately when the system becomes idle. They take a few minutes to reach near ambient temperatures.
dump the stock thermal pads, try some IC7 if available or AS5 if not and after seating pull the HS off and see that it is spread out properly.
Won't be perfect as you haven't applied heat yet but it will tell you if your making good contact.
I learned the hard way on this by using a set of coolermasters designed for socket 604 and socket 771 although the same bolt(holddown) pattern has the cpu sitting just a tad lower.
I saw 92C at bootup and learned REAL fast..:D
The fans don't drop in speed really fast, the temps drop really fast. Once the temps are below the full speed setting in my Z7S bios they turn off from full speed, maybe a few minutes like you said. This I'm sure you know is controlled by my bios settings. I could set it to 70c if I wanted. Default is 55c.
I know my HS's are making contact because how else would it boot and run at the same temps for a week plus the benchmarks? Really? :shrug: :rofl: Really, thats hilarious.
Thank you all for your responses but I'm still not willing to concede my HS's are not touching my CPU's correctly. That in itself is laughable after a week of benchmarks, etc. Like I said they are cool to the touch @ 100% load and nothing shuts off or down. Stock Cooling FTW. :clap:
EDIT: I want to add something. There is stock cooling with a fan and heatsink, and stock cooling with only a heatsink. I am not using passive cooling but active cooling and these things don't mind the heat I throw at em with a fan. I happen to ALSO have 2 servers using the passive HS only cooling (dual XEON 5410's) IN 2U's and they are doing very well, and have been since March. Thanks for everyones time and comments.
By having enough contact to stay below the point at which the CPU downclocks or stalls itself to keep from overheating, of course. Its a feature of current Intel chips.
You should. It might be the HS's are concave or convex. It may also be that the IHS is not touching the CPU cores well.
Here's a 5340 that had poor core-ihs contact: http://www.mediafire.com/imageview.p...j1wdra&thumb=6
I have 9 fans in this rig, much more than my 2U racks. The stock non passive cooling in this rig cools the cpus from 100% to idle temps in less than 2 minutes, so I know they work. :yepp:
Lets say I reboot from 100%, at boot the fans are slow then burst for about 5 seconds, upon boot into vista, I'm back to idle temps. :clap:
You were and I appreciate it. I had just thought of that before and tested it. I think you all just want me to get new fans and heatsinks when all that is really required on these cpus is a heatsink - and mine don't get warm.
There is an Intel plant here in Rio Rancho, NM bout 10 minutes from where I am, chances are you buy these processors. They won't sell me one without knowing the passive or active cooling is enough for 100% use would they? No because I would send it back if it didn't cut it. :) I've never sent back an Intel CPU. Anyways your warranty doesn't cover after market coolers now does it? Nuff said I think.
Hey, I don't care what you use as long as it's working.
I use a pair of Dynatron H46G's with a modded pair of 80mm Vantec tornadoes on them.. Cost app $100.00 for the 2 HS and 2 fans from Newegg and works excellent but I am sure there are alternatives.
Thats how we all learn,spreading the info back and forth.
We were just concerned that your HS weren't making proper contact.
I appreciate your input. It could be a lot of things. The fact remains however that the cpus are CONSTANT temps at idle after a week and only jump under load. That means I have good contact, but correct me if I am wrong. I'm using stock Intel thermal pads after all - but they haven't failed me ever before. Like I said these CPU's don't even need a fan and thats fact because I have 4 in 2U's running fine for months without fans over the heatsinks. They are the exact same CPU's and you can check for yourself.
Cheers.
The CPU's are a huge investment and I understand the aftermarket for coolers etc. What I am saying and defending is that these CPU's run without aftermarket coolers or fans, STOCK everyday in and out in rackmounts, been there, done that, working great. I chose stock cooling, but of course I haven't upped these 2.3's to 5Ghz either. LOL.
I don't need the best score on WCG or folding. I don't feel the need to post scores from SETI where I know both Frank and Seth. Why? Braggarts.
My systems I need to do work for me, and if they work under load, I'm a happy customer.
Stock cooling FTW, again. :shocked:
The heatsink (s) should feel warm to the touch at full load.
In my system, the heatsink is around 38°C (measured with digital thermometer) when the cpu is at full load (around 57°C)
It's not possible it feels cold when you're seeing 90°C in my opinion.
These 2 boot at 30 or 40c - I'm not worried anymore after talking to Intel. Stock cooling, nothing super fancy like modifying a heatsink fin and crap like that. I also have a p4 that runs 80c normal, it's been fine for over a year. Cheers. Mine run hot and don't crash, nothing to complain about here. :rofl: Hey I had these to 127c actually. :up:
My ambient temp is below 38c and yes my heatsinks are cold to the touch, as is any part of the case other than the GPU or the RAM or the NB. Those are warm. The CPU heatsinks are NOT WARM. I am not willing to debate this since I'm the one judging the results. Anyways, I don't even need a fan on my cpus and I can refer you to plenty of documentation to support that.
Have a nice day with your full load build at 57c and :rofl:. :) Mine run way hotter. I guess mine work harder. lol...
Do you run stock clocks on those 5410's? The lower the clock, the higher the stable temp threshold.. mine crash at 3,2Ghz when they hit 80C real/90C Everest.. I tried without fan just to see, lol ;)
Oh and in my rig, everything gets rather hot.. NB, Rams, even the Heatpipes from the HR-01's. But temps are ok even at 30C ambient, plus this system is a rock at FSB 430 :up:
I would say cold heatsinks are a bad thing. I'm sorry but I just cringe whenever I hear "I get X(high temp imo) and the heatsink isn't even warm!" If I see high temps anywhere, I expect the heatsink to burn. Of course, it could always just be the temp probes on your CPU are fubared.
Sounds like he wants our help but only if it's what he wants to hear lol.
Extreme temps and cold heatsinks = something isn't right.
Never seen a stock heatsink that was worth very much.
Still running stock but I will try 400 FSB this weekend at some point.
Here is a picture of my heatsink + fan (active) and a pic of the (passive) heatsink.
http://67.91.114.164/server_xeon_1U_2U_heatsink.jpg
As you can see the passive heatsink is rather larger. Al models from the 5405 to the 5450 come with the option of active or passive, so I think it's a rather well proven point that you don't need to go active cooling. Either way like I said before I'm not trying to cook these by overclocking too much which would in my opinion require better cooling. However, since the heatsink and fan for each model from 5405 - 5450 is identical from Intel, I think I'm set up to 3Ghz.
Part of the reason my heatsink for the cpus aren't warm to the touch is because of the fan directly above them, and the room they are in. Also I'm not feeling them from the top but rather the thick base/bottom (one piece unlike your HR's), and the side fins. There is a 10d temp swing from my upstairs and downstairs, and currently the rig is on a table, in the case with both sides open, a top exhaust fan, front input fan, dual rear exhaust fans so it's getting a lot of airflow downstairs where the cold air shoots out from the ceiling.
Once I get my huge Sigma SD-10 batts recharged I'll take some professional pics for ya all. ;)
With all due respect I am listening. :) I was thinking the same thing, however I cannot ignore the logical results which are that under load my temps are higher and at idle they drop down to the constant idle temps which they can hold for over a week and do as I take temp readings each day at the same time idle. If the cooling wasn't working, they simply wouldn't boot or hold an idle temp, nor would they drop quickly from load. That's just the facts. :welcome:
I've never seen a 1U or 2U unit from Dell, HP, or the like come with aftermarket coolers on Intel CPU's either, and they work fine for years. Passive cooling works, and so do stock HS's with fans; trust me.
