Originally Posted by
Ghostleader
If you use stock CPU cooler or similar, the air flow from the optional fan disturb the air flow from the CPU cooler and vice versa.
If you use a TRUE, Tuniq or similar cooler there is okey to use it, no air flow interference.
I did use it as it gave additional cooling and brought down the heat on my NB. I donīt remember how much lower it was.
I run my NB between 1,41 and 1,71, depending on how hard I push my memory and to get me the lowest possible tRD and right now Iīm on water on my NB and itīs never above ~35C even if I push 1,71 throu it.
