nice one forsaken whats the fpo batch code again a low vid chip 1.0375 same as sepanders higher up
Welp still working on mine Sadly only 6hrs prime stable at 1.304, almost 11 hrs before it fails at 1.312 trying 1.320 (1.34225 bios) now been going about 1/2 hr so far :)
this is at 450x9 for 4050 its it moves between 53C and 58C while under load core 1 is usually 1 to 2 degress lower than core 0 but core 1 seems to be the one failing Prime 95, kinda sucks as I guess heat isn't the issue in this case Its cold in Ohio today :) lol
Thanks mate.
From Microcenter
Q745A372
12/20/07
Running prime at 523x9 4707.Almost a hour so far.Will update if/when i get to 4hrs prime stable.
Edit:Good buddy(zuck) and yourselfe?Thx for the volts tip.Just had to find some intestinal fortitude with uping the cpu volts.
Thanks for the info X.T.R.E.M.E._ICE:p:
Guess that is enough from me about the "T" thing. Anyhow, I finally got my E8400 installed and I'm gradually bumping it up. Was able to get to 3807MHz on stock volts, now I'm having to bump up the juice to go beyond. Got a ways to go, 4GHz here I come.........................
Update: Now running @4050 1.328v still Prime testing.
maybe anybody can collect all results in the first post for better overview?
that would be great.....
I have the same Batch as you and im able to run it at 4ghz @ 1.35 vcore.
http://i74.photobucket.com/albums/i2...8/E8400P5K.jpg
see ?
most people running P35 need higher vcore for lower overclock :shrug:
I have an E8400 but my VID is 1.1xxx VID which is a poor OC-er compared to some of us here which has 1.0xxx VID.
On a Foxconn Mars, I need 1.425V to get it stable at 4.05Ghz. This is terribly bad and can someone tell me if I'm getting this right?
Asus P5K-E P35 4GHz 1.216v
Gigabyte P35 DQ6 4GHz 1.200v
I'm gonna use my good old P5B Deluxe mobo for my new, upcoming E8400, will see how it performs! I will go for 9*500MHz... :) The mobo can do 500fsb for sure, now its all up to wolfdale!
you guys are freaking lucky with your vcore. I dont know whats wrong with mine coz i need 1.35v just to boot 9x450 lol. Maybe i need to relax ram timings a little.
batch Q946A446 if i remember correctly
Some are worse than others but I really gained a lot by messing with VTT and GTL settings.
