stoopid fast setup...you have that RE singing like a young man in front of the feds.
and the gauntlet has been laid down for sub 8 min which most should be able to do on air...this should be the battle category with everyone able to compete. nice way to get the party started ;)
yup, those numbers look bang on, nice run :up:
it is slow. for 45nm, regardless of memory used, it is slow. make sure LSC is enabled and keep working/tweaking...there is plenty of room to improve.
hahaha, i have never seen that before. i guess the checksum is solely based on the time? no real need to post other 9m59.x runs if they aren't any faster than the one posted.
i don't know what to say George, your handicap (inability to get CW working) baffles my mind. platform after platform it doesn't work for you which clearly means it has to be OS related but i am stumped.
one of the best out there...that and 01/AM3, i have been spending far too much time on both. nice run BTW...isn't that the best when your trying to squeeze that last tenth of a MHz :D
big update done which will be followed by my first couple i7 results later tonight. not sure i am going to be able to squeeze past that 4460MHz 7m59.x time Dsjjang has put up with this current setup. i still might be leaving a bit short with CW so perhaps more work is needed there...but 3x2GB kits of memory smoke 3x1GB at the same clocks, first thing i have figured out with i7 :up:
