Hi, i'm back again with the same problem with this mobo : BSOD as I try to install windows xp pro with the usual message IRQL_NOT_LESS_OR_EQUAL (with the same 0x0... address).
I am getting this message after sending back my OCZ memory and trying out my newCorsair DDR3 memory (which is supposedly the most stable and probably the most expensive). I installed the corsair memory (
http://www.newegg.com/product/produc...2E16820145183), went into BIOS and chose setup defaults, BSOD appears as I try to install windows. I went through the usual alterations in memory overrides, using setup defaults, manufacturers settings, alternating sticks in slots and increasing voltage step by step, still the same BSOD.
After having checked out all the peripheral devices (gfx card, hard disk, memory) I am left assuming the problem is either the mobo or the processor.
Question 1 : Is there any way of telling if my Q660 processor is faulty here through BIOS or DOS ? (I mean, it reports the 'correct' values in bios, so...??) ?
Question 2: The only performance settings I have ever altered out of setup defaults are the memory override. I have never altered either the BUS or Processor overrides. Should I adjust the settings in these to help overcome this problem I am having ? Will adjusting the PCI express burn in mode percentage help anything (I am a bit nervous as I have quite an expensive ndvidia card here) ? What about the PCI latency timer ? The PCI Bus frequency option is not available ? What about the processor override settings ? Usually, I leave these settings at default, but I have exhausted so many possibilities now, I think these are the only ones I have left before I need to return either my mobo, my processor or both.
Any help or education in PCI Bus/Processor settings here would be really appreciated !
Final question : Am I stating the obvious here, is my Mobo a lemon !
