GameKiller, the problem was ATI 9.5 CCC. It was loading on startup and I really did not pay too much attention to it. It was the only thing I had not checked from the startup menu. Is this a ATI driver or BOINC conflict?
I'm glad you found your problem doakh! Hopefully you'll find a fix for it soon! Good luck. :D
hi, it's been a while since i've DL'ed a new BOINC version. my crunchers were running 5.10.45, but recently i had to format. i also built another one. what's the most recent, stable, and will give the most PPD version for 32bit XP? is it 6.6.36? (no betas please, i'd like to set it and forget it, not something i'd try out and might have to reinstall).
6.6.37 beta is available for:
Windows 32 bit
Windows 64 bit
OS X
OS X command line version
Linux 32 bit
Linux 64 bit
6.6.38 beta is available for:
Windows 32 bit
Windows 64 bit
6.10.0 beta is available for:
Windows 32 bit
Windows 64 bit
OS X
http://prohardver.hu/dl/upc/2009-08/...ati_stream.jpg
6.10.1 beta is available for:
Windows 32 bit
Windows 64 bit
6.10.2 beta is available for:
OS X
Linux 32 bit
6.10.3 beta is available for:
Windows 32 bit
Windows 64 bit
Edit:
OS X
Linux 32 bit
Linux 64 bit
6.10.4 beta is available for:
Windows 32 bit
Windows 64 bit
Edit:
OS X
Edit2:
Linux 32 bit
Linux 64 bit
Hmm... anyone else getting tempted to try out 6.10.xx, and some ATI gpu crunching? although its milkyway or collatz.... :|
6.10.5 beta is available for:
Windows 32 bit
Windows 64 bit
Edit:
OS X
You gotta quit posting new versions every couple days...I just went to .4 yesterday. Thanks for you time and effort keeping us updated!
Thanks, trying to be useful here :)
6.10.6 beta is available for:
Windows 32 bit
Windows 64 bit
Edit:
OS X
Dammit,just did it again :rofl: I just installed .5, then thought to myself, I better check. Sure enough we are on .6 now :shrug: :shakes:
I really appreciate you taking the time to keep us updated:up:
6.6.40 recommended is available for:
Linux 32 bit
Linux 64 bit
Edit: 6.10.6 beta too:
Linux 32 bit
Linux 64 bit
6.10.7 beta is available for:
Windows 32 bit
Windows 64 bit
6.10.8 beta is available for:
Windows 32 bit
Windows 64 bit
And two hours later:
6.10.9 beta is available for:
Windows 32 bit
Windows 64 bit
Edit:
OS X
Running 6.10.7 with Collatz on the ATI. Lotsa points but graphs only showing CPU credits...
6.10.10 beta is available for:
Windows 32 bit
Windows 64 bit
Edit:
OS X
6.10.11 beta is available for:
Windows 32 bit
Windows 64 bit
Edit:
OS X
Edit2:
Linux 32 bit
Linux 64 bit
6.10.12 beta is available for:
Windows 32 bit
Windows 64 bit
Nice. Thank you.
Running 11 on the 955BE. Wetstone 1.5k higher then regular client but the other is 0.5k lower :-/
