In my other thread someone said it's a known issue with coretemp that it randomly reboots some machines. So I guess that's that.
Guys just use 0.94 ;) :D
Damn I ordered the 9650se the other day as well for my P5K, I wonder if I should just return the card when it arrives or try it myself as well. Grrrr, was really looking forward to using this card too. I guess I should have just stuck with my hpt2320 but I wanted to go with something with a little better raid5 performance.
Does the P5K Deluxe have solid caps or not?
have you looked on Asus' website for the possible answer?
Got my P5K-Dlx set up. No floppy but flash to 0311 bios with ez flash/usb key was smooth. Setup bios a little and then XP installed so fast to my raptor on one of the sata ports. Just adding drivers now, is there anything worth using off the Asus DVD that came with the board?
edit - I mean the asus extras. I don't want a bunch of asus bloatware if I can avoid it.
Should one take off the SB HS, NB HS and Mosfets HS and apply AS5 for better heat transfer? I think I'm gonna do that when I get mine.
Run the Asus DVD. When the dialog pops up select the "ASUS Install - Drivers Installation Wizard" and then the "Customize" option. You'll notice that all of the drivers on the DVD are newer than what Vista installed. The driver that controls the "SM Bus System" is the "Intel Chipset Software Installation Utility" which Vista didn't install.
Thnks for the info eva as usual faultless.
Got my board running today. now running orthos @ my last commando 24/7 of 9x400 @2:3 which i hope is my starting point.
On the commando have been running matrix raid 0 with 4x80gb hitachi sata 2 drives. had seen a few pps having issues with raid . when i plugged in all my hd i thought i was going same way, although all 4 drives where detected only 3 were seen in bios as being part of the array. fortunately i keep asmall xp install on my data drives , booted to that. Once i'd updated the matrix drive manager to the version on the asus cd & rebooted, my original arrays where found & i was able to happily boot & update that install.
Why updating an xp programme should work better than new drivers i'm not sure but hell it works fior me:D
actually, asus says all the caps are high quality conductive polymer caps...just needed to do a web search on polymer caps to find the answer to it being solid...here you go.:)
http://www.chemi-con.com/files/PSA.pdf
Can the wireless card be removed? It looks like it might be able to.
Yes, the wireless can be removed. I'm pretty sure that FCG made a thread about the P5W DH Deluxe board and showed how to remove the wireless from that. This board should be exactly the same in that respect.
It's just a small screw holding the wireless into a slot on the board.
Thanks, its one thing I really don't like about this board. Mine got here a few days ago but I have not had time to play yet. I'll search for the thread.
I wouldn't worry just yet as it turns out this this may be a lesson in 'newest isn't always best'. As a matter of course I updated the firmware on the card to the 9.4.1.1 set before even putting it in to the P5K as I had never had a firmware or compat issue with any other 3ware card. I spent the best part of yesterday fitting the 680i in to my case and fired it all up with the 3ware in there and first boot was OK, but after that the machine would either halt on the mediashield bios loading, or get part way through the 3ware bios and die, or come up with cannot recognise card, contaxct bios vendor etc etc. I have just downgraded to the 9.4.0.1 firmware and the machine 'appears' to be behaving just fine. I am currently slipstreaming the drivers onto the xp cd.
Later on I will slap enoguh stuff in to the p5k mobo and fire it up with the 3ware on and see if it too starts to behave. Fingers crossed tbh as I do prefer the Intel boards.
Well the reversion to the 9.4.0.1 firmware did the trick. I put the entire rig back together using the P5K again and everything is happy. If a problem with RAID is acknowledged and fixed then I will most likely go back to the onboard but for not I will stay on the 3ware. I still have the problem every few boots of the paused dim xp loading screen for 30-40 secs and I have no idea if I still get a BSOD when installing the X-Fi driver cd as I just web downloaded but heh ;). I will send 3ware a note this week regarding the loss of compatability with the current firmware.
The difference was that I have a lot of experience with 3ware cards in my line of work, this was the first one that ever gave me comptability trouble (I was using almost all of them in servers though) so I was quick to blame the P5K going on the other niggles it had :D. There is always a first time for everything hehe.
