it's been out nothing like that long.Quote:
Originally Posted by Evanesco
Now, my P5N-E SLI has & it still doesn't have a better BIOS imo than the (buggy) release :slapass:
What cpu clocks and voltages you had for 110A ?Quote:
Originally Posted by fhpchris
my E6600/Abit AB9 QuadGT adventures begin http://i4memory.com/showthread.php?t=3760 :)
Eva2000 how u like the board so far? As far as disappearing Lan and Audio, don't use onboard stuff. Problems solved. Besides using onboard stuff takes up cpu cycles. With regards to bios not taking some of the changes, I had to do it twice before the bios would take my fsb changes but otherwise fine. Overclocking uguru is fine, just dont change any volts using uguru.
~3900ish running orthos and 1.69v real @ idle.Quote:
Originally Posted by eva2000
~187 watts :nono:
Hmmm that stock NB cooling is very interesting, it was exactly what I had in mind as an improvement to the asus crappy heatsinks.
Yeah I'd like to know from eva2000 and others how they like this board compared to the P5B-deluxe wifi, if they have tried one.
1.69v air cooled ?Quote:
guys only 2 issues that bug me for Abit AB9 QuadGT
1. auto shutdown and restart on any 'bios save and exits' regardless if any settings/strap/divider changes are made
2. lack of memory sub timing options
fix those 2 and the board will be up there with P5B Deluxe at least.
have you tried a fan?Quote:
i'm using a small 40x40mm fan. my average pwm current now is 83a and average pwm temps are 66c. running a e6400 at 1.5475v which is more like 1.48v in real.
on the other hand, this is just 123w compared to your 187w!
what do you mean? you like the heat pipe on the quad? or the heatsink on the nb itself?Quote:
Originally Posted by serialk11r
i'm at 3807mhz at 1.52-1.54v orthos small ffts load with 98-99A current on PWM with 48-53C PWM load temps :)
Eva,
How's this board do with 4 sticks of 1GB ram? I am thinking about building another rig around an E6320(when they are out) and a solid 965 board. I'd like 3.5-3.6 on air. So I'll need a board that can handle 500-515FSB.
at stock cooling?Quote:
Ask me in a few weeks :)Quote:
Originally Posted by Blacklash
Only just set up my board and i sold 2x1GB 6400PHU2 HZs from my 4x1GB set so can't test 4x1GB right now
yes, stock PWM heatpipe heatsink if that's what you mean - see what i did for improved cooling though http://i4memory.com/showthread.php?t=3760 :DQuote:
Originally Posted by fgw
although PWM temps now risen to 53-58C as the orthos small ffts load duration gets longer hehe
looked at your thread on i4memory: although its hard to say if the additional tim between the pwm chips and the stock tim made a difference, i'm pretty sure the 120mm fan blowing to that area changed a lot! i'm using a 40mm fan and even this one is a big improvement!Quote:
btw, seen you are running rather high vmch (1.65v) and vtt (1.40v) for 400MHz fsb! do you really need this? i currently run 450MHz and use all stock except vcore which is at 1.5475 right now, but this is mainly to test my cooling system. think i could lower it a bit too.
i haven't tested anything lower yet.. i've only had the system up less than 20+ hrs total since i applied AS5 on cpu IHS - not even enough time for AS5 to fully cure yet heh
3807Mhz at 1.52-154v
Next stop 3807Mhz at 1.52-1.54v load :)
CPU idleQuote:
Abit AB9 QuadGT Bios settings used:
OC Guru
CPU Operating Speed: User Defined
- External Clock: 423Mhz
- Multiplier Factor: x9
x - Estimated New CPU Clock = 3807Mhz
- N/B Strap CPU As: PSB1066
- DRAM Spec. (CPU: DRAM): DDR 533 (1:1)
x - Estimated New DRAM Clock: 423Mhz (DDR846)
- PCI Express Clock: 100Mhz
Abit EQ
Voltage Control: User Defined
CPU Core Voltage: 1.595v
DDR2 Voltage: 2.20v
CPU VTT 1.2V Voltage: 1.4v
MCH 1.25V Voltage: 1.65v
ICH 1.05V Voltage: 1.05v
ICHIO 1.5V Voltage: 1.5v
DDR2 Reference Voltage: 0%
CPU FanEQ Control: Disabled
FAN FanEQ Control: Disabled
CPU Feature
Thermal Control: Disabled
Limit CPUID MaxVal: Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
EIST Function: Disabled
Advance Chipset Features
DRAM Timing Selectable: Manual
- tCL = 4
- tRCD = 4
- tRP = 4
- tRAS = 12
- Command Rate: 2T
- tRFC = 42
http://fileshosts.com/intel/Abit/Abi.../cpuz_idle.png
CPU load
- @100A current draw on PWM = ~1.52-1.55v x 100A = ~155 Watts
- PWM temps were respectable 52-58C average not bad :)
http://fileshosts.com/intel/Abit/Abi...rthos_load.png
Super Pi 32M
http://fileshosts.com/intel/Abit/Abi...3m37s437ms.png
http://fileshosts.com/intel/Abit/Abi...ms_voltage.png
@eva2000
nice u got the board now i know that some of my questions will be answered :)
well i mostly like to know how do the clocks compare to the P5Bdlx at same load voltage, and also the temperature...asking since my cpu on my friends mobo (P5W DH) can actualy run a little higher at same voltage and bit cooler also and was it the Bad Axe that run the cpus a bit cooler than the Asus at same voltages?+
edit: I see that you got the HR-05 also......I had an idea of getting it and cutting up the base paraler to the heta pipe to make it slimer and stick it on the pwm when i get it.....basicly only leaving it a little wider than the heat pipe, can you tell me if the lenght would be alright
4 sticks seemed to work i mixed some g skills and cellshocks didnt notice a diff till my memory didnt want to go more then 3.3.3. 430 then i was like 4 Sticks duh
never got to install HR-05 so not sure... i wouldn't risk shorting the pwm and surrounding components.. just be careful if you hack up a heatsink.Quote:
Originally Posted by Millyons
no, it simply won't fit! thought at this already. i have installed a hr05 (although the sli version) on my aw9d-max. base is the same anyway. even if you cut it to be small enough to fit it in between the parts surrounding the pwm chips, it is simply to small. the hr05 has a base size of 30x30mm. the pwm's are wider apart.Quote:
the stock heatsink is just fine! no need to replace it. just add a fan and let i blow at the pwm heatsink. i use a small 40mm fan but you can go and use a 120mm fan as eva did! i didn't even change anything to the tim.
because i'm cooling my nb with water i had to remove the whole heatpipe assembly. after a few minutes of hesitation i just cut it apart and istalled the pwm heatsink alone together with a fan. running it without the fan, temps reached 100c within minutes. the small 40mm fan is able to keep temps below 70c when the cpu draws a current of 83a! if the 40mm fan is able to reduce temps by 30c under that conditions, what do you think would a 120mm fan do? look at eva's figures ...
thanks thats what i was wondering about since i dont have a hr05 but was thinking about ordering it.....although it would have been sweet if it fit, would also probably be cooled by the exshaust
you are right, i thought the same way! but as experience showed it is simply not necessary. a fan blowing at the stock pwm heatsink will work perfect!Quote:
btw. i figured out that both, nb and sb gets real warm. i measured up to 50c on the heatsinks with an thermometer. even if my measuring is a few degrees off, this components get really hot! recommend also placing fans over them ...
for all people that have 2 x 1gb ddr2 cellshock pc 8000 4-4-4-12 on abit quad gt.... can post your ram setting that used in bios? cas etc??
i'm having a lot of problems with 4\5.. and i can't pass 540 mhz 4-4-4-12....
umm thats the max on the mobo m8 sry but you have hit the wall =/ very sad but true maybe a new bios will fix it but 540 is most likely your max mine was like 56x =/
do you mean that there is a wall around 540 mhz-550 mhz at the moment for the max mem frequency?Quote:
Originally Posted by momomo6789
Originally Posted by ztop
Depends on your memory, but there is a hard cutoff at 580~581.
