Hey everyone, so my brand new P5B Deluxe arrived today, which means I'll be building a new C2D rig (E6600, Scythe Mine) in a few days, and I have some random questions about the board. Any help you guys could give would be appreciated.
1)
This thread on the P5W recommends taking the NB and SB coolers off, cleaning them and re-applying them with AS5. Does this void the warranty? And how necessary is it? I don't want to do it unless the board would be really hot/unstable otherwise.
2) That same thread recommends putting the board on the antistatic bag when working on it--and some posts later, someone else says that's actually dangerous because static builds up on the outside of the bag. So which is it? Is that safe or not? If not, what should I put the board on? (BTW, I always wear an antistatic wristband attached to the computer case when working on anything, so I'm not too worried about static.)
3) The "optional" fan that comes with the board, that mounts on the fins of the NB cooler by the I/O ports--the sticker says it's only if you're using passive/water cooling, which I'm not, but I don't really see the harm it would do, especially if it keeps those fins cooler. I'm using a Scythe Mine, blowing towards rear exhaust. Should I put the optional fan on anyway?
4) I've got 2x1GB Kingston DDR2-667--which slots should I put them in? I'm confused b/c the manual says the channels go A-A_B-B, but they're colored yellow-black_yellow-black. I thought same color usually meant same channel?
5) I don't have any use for the Wi-Fi at all, and it looks like the Wi-Fi module takes up 2 more USB headers. Can I take off the Wi-Fi module and hook up those USB headers to normal ports, or is that impossible?
6) My HD is a Seagate 7200.10 320GB SATA drive, and I'm not using RAID. I can't seem to find out for sure if Windows XP Setup will recognize that drive already, or if I need to make a driver disc from something and hit F6 at setup. I know you do for RAID setups, but I'm not doing RAID, so do I have to make a special disk from something?
7) I've heard different things about how I should set BIOS settings like VCore (Auto or not), C1E support, Max CPUID Value Limit, and Speedstep. I want to OC eventually, but I'm a total n00b and just want to get the rig working and stable first. How should I set those?
