A few questions....
1. How can I monitor temps in windows with this board?
2. How do I set up clockgen to work with this board?
3. Does this board lock PCI or does it work on a divider? If divider, is it a divider of pci-e or System bus?
4. I can do whatever I want up to 415... then nothing 416-419 works, then 420 works, then nothing higher works. I've raised every single voltage and nothing lets me go higher in bios... system either locks up posting or reboots right after posting with higher than 420, or 416-419 set. I am using the latest mod bios. Do I have to use clockgen to get higher or do you think I've reached some sort of chipset or cpu limit? (Ram is fatbody and does 4-3-3 @ 840 @ 2.1v, so it's not the problem.)
