Patriote, an awesome job you did there. Really good cable management also. :up:
I like the case! Too many fans is the only negative point ;)
Well, why would i edit a post that nobody would see anymore ? I mean, i post pics so that ppls can see and maybe that will give them ideas for future builds!
BTW: Ah so thats why that particular rig reminded me of something! I had seen it somewhere but couldn't pin-point out where.
____________________________________
I actually hate white lights and clean water ;) My water needs to be colored or else ill think nothing is running through my tubing lol
But guys, all the fans are actually all Yate loons silent fans! Only the 3 pull fans on my rad are Scythes. And you guys see 2 custom fan controllers in front ? Well, i have full control over all the fans in my case. And let me tell you that when all are turned down, the case is super silent!
The cable management turned out to be not bad :)
Thanks for the kind words guys :)
Zostava:
CPU~ ~ ~ ~ ~Intel C2D E6300@ 3003MHz (7x429MHz) 1,41Vcore
MB~ ~ ~ ~ ~ Gigabyte P965-DQ6 bios F9
RAM~ ~ ~ ~ ~4x1GB Corsair Dominator TWIN2X 6400D4C@ 858MHz 5 5 5 15 2T 2,22V
GK~ ~ ~ ~ ~ eVga 8800GTS320MB @ 621MHz/1900MHz
ZDROJ~ ~ ~ ~Enermax Liberty ET500W fan @5V
HDD~ ~ ~ ~ ~Seagate Baracuda 7200.10 320GB
DVD~ ~ ~ ~ ~Pioneer DVR212 sata
DVD~ ~ ~ ~ ~Samsung SH183 sata
:CASE~ ~ ~ ~ Thermaltake Armor Jr. VC3000SNA intake fan Thermaltake Sleeve Bearing Fun 120 and outake fan Noctua NF-S12-1200 @5V
Chladenie:
Pumpa~ ~ ~ ~Swiftek MCP655B whitout speed controler
CPU~ ~ ~ ~ ~Swiftek Apogee GTX
SB~ ~ ~ ~ ~ ~Swifkek MCW30
NB~ ~ ~ ~ ~ ~Swiftek MCW30
GPU~ ~ ~ ~ ~ D-Tek FuZion GFX
Hadice~ ~ ~ ~Tygon R3603 1/2ID 3/4OD
Fitings~ ~ ~ ~ DangerDen HighFlow Fitings 1/2OD 3/8ID
Radiators~ ~ ~2 x Swiftek MCR320 whit 6 x Artic Cooling Fan AF120@7V
Expa~ ~ ~ ~ ~Cape Colpex Pro 250mm
Temperatur (27°C in room):
CPU: IDLE 27°C BURN 48°C(max po 30hod ORTHOSU)
GPU: IDLE 39°C BURN 43°C(max po 5hod 3Dmark06)
Chipset: IDLE 27°C BURN 45°C(max po 30hod ORTHOSU)
http://img182.imageshack.us/img182/552/19an7.jpg
http://img211.imageshack.us/img211/1467/p7061514mc8.jpg
http://img73.imageshack.us/img73/277/p7061511am6.jpg
http://img73.imageshack.us/img73/593/p7061496ix9.jpg
http://img176.imageshack.us/img176/842/13kompletmz5.jpg
http://img123.imageshack.us/img123/3...kompletnf0.jpg
http://img504.imageshack.us/img504/97/23uc0.jpg
have you got any ramsinks on that 8800GTS of yours?? you should also put ramsinks on that mofsets of yours too
My new rig :) My daughter aproves it :up:
Not a big fan of small tubing but damn... That looks great trouble2000! I like the cable management as well! Oh and cute lil girl you have there :)
Oh and can you say "Fingerprints mess?" lol :D
very nice
yes. its cape colpex
14fans? Thats a WR! :D
Thats a sweet looking case nitteo:up:
http://www.xtremesystems.org/forums/...1&d=1186355892
That is awesome! Might have to shamelessly copy that in the V1200B I've got on order.
With only 1 DDC and 3 rads (1 a GTS), that's got to be restrictive as all hell. Making matters worse is the AGB res on the DDC.
Well true, if you're refering to me copying the design I should have explained better. I'll be copying the overall look, loop layout will have to be different due to my hardware (see sig for a general idea). Trouble2000, do you have the sizes you cut the black acrylic down to still handy? If possible could you PM them to me?
