Try not to use 1.5x UnCore to RAM ratio, go for +1. I had issues with lowest multi.
Well, you just might need more voltage. :D How much are you feeding it with?
I use 1.475V on a daily basis, LinX 20 loops stable, but keeping temperature under control is a must.
But, as Cryptik said...
...so, be carefull.
BTW, I have a problem with my R3E. (first time I guess :D)
Integrated sound card went berserk, not detecting plugged cables.
I always used Win7 driver, as I don't need any settings, just volume and to hear the sound.
Now it's showing that speakers are not connected and the headphones are, no matter what is plugged where.
Best I had, when installed Realtek drivers, is having sound on left channel, but it was showing that microphone and speakers are plugged in front panel, which is not even attached.
Speaker are all the time plugged in where they belong.
Tried reinstalling/deinstalling/installing drivers, no luck. Tried reverting to my tweaked and pimped copy of OS with Ghost Image, which worked fine of course, no luck. Installed fresh copy of Win7 - same thing. :mad:
Any suggestions before RMA?
