Builds i have been working on:
http://www.computerlounge.co.nz/imag...quidCooled.jpg
http://www.computerlounge.co.nz/imag...led_image6.jpg
http://www.computerlounge.co.nz/imag...led_image3.jpg
http://www.computerlounge.co.nz/imag...led_image4.jpg
My rig:
http://home.comcast.net/~nickbaldwin/site.html
and
Like it on Facebook:
http://www.facebook.com/photo.php?fb...type=1&theater
@xFEARx3 can you please post some load temps .
I'm very curious what kind of temps are you getting from your LT
And i'm not touching it anymore....It's good enough...:ROTF:
http://i765.photobucket.com/albums/x...s/DSCN0071.jpg
http://i765.photobucket.com/albums/x...s/DSCN0072.jpg
:D
@Shadow0001 - Your rig is really good enough :)
Do you have a Lian Li case?
LiAN LI v2120x to be exact(all black interior), and yes it is a large case and started out with a lot of room to play inside, but sure didn't end up that way...:ROTF:
It's also heavy as hell too the point of being near hernia inducing each i have to pick it up, put it on the table to do anything inside...:p:
My old STC-T01 dual loop system was almost 29kg, THAT sucked to try to move.
Now im down to a single loop in it and it still weighs damned near 27kg
Since my last post I've changed mobo, GPU's, pumps, tubing and colour theme so here are new photos:
https://rapidshare.com/files/2626070807/All_800.jpg
https://rapidshare.com/files/1744261...U_NB_2_800.jpg
https://rapidshare.com/files/1518903009/Mobo_800.jpg
https://rapidshare.com/files/3795745418/SLI_800.jpg
Theres some pics of my last modding project "Orange Line v2.0".
Hope you like it :)
http://img855.imageshack.us/img855/4803/dsc02601ul.jpg
http://img39.imageshack.us/img39/7117/dsc02610lw.jpg
http://img14.imageshack.us/img14/5421/dsc02627km.jpg
http://img809.imageshack.us/img809/3632/dsc02628l.jpg
Cheers :D
We like it (except the colour of the hold-down plate of your cpu-block and your blocks top, seems to have some colour mismatch with the rest)
but rules say about 4 pics maximum per user...so i think you have to edit your post mate...choose the best...
EDIT : nice res...:up:
Temps are:
3x GTX 580 between 47°C and 41°C (max. 43°C @ COD4).
i7 980X @ 4,2 Ghz under 50°
Rads: Phobya 420 @ 800rpm + Mora 3 @ 780rpm
http://www.abload.de/img/2qs3a.jpg
http://www.abload.de/img/24c8f.jpg
http://www.abload.de/img/2a7go.jpg
http://www.abload.de/img/30d6a.jpg
Thanks xFEARx3,very clean and great temps,didn't know you wore running Phobya 420 as well
very nice rig
I just added new stuff to my existing WC PC. I took these pictures from my camera phone.
GTX 580 HC2
XSPC 240 at bottom of the case. (no pictures, too lazy)
Fesser Black tubing 3/4 inch
EK Supreme Nickel
http://i288.photobucket.com/albums/l...e/IMG_0051.jpg
http://i288.photobucket.com/albums/l.../Photo0050.jpg
http://i288.photobucket.com/albums/l.../Photo0054.jpg
http://i288.photobucket.com/albums/l.../Photo0051.jpg
Hi,
Alot of real nice looking setups here.:eek:
Mine on the cheap and almost done. Sheetmetal cut out for the top Rad
and the Senic Cruiser look last to do.
Ivy going in here when its released along with single 6990 on water.
No mo CF:down:
Pics
Later:D
@Irocing..nice woodwork ;)
