I had tested one at a time a while back, but not since things got worse again and not with the right settings I am sure. I am doing so again at your suggestioning this morning, just booting up with one stick, and running the system through paces, with the recommended settings from the G-skill thread.. Thing is, much to my dismay, neither stick so far has been acting up when all by its lonesome... I guess I need to do memtest again one by one and see if that reveals anything..
Is it possible that there is problem with dual channel on the motherboard? Things got so crazy when I was testing yesterday, and now today, going with one stick at a time, I haven't had one lockup..
F2-6400CL5D-2GBNQ ---DDR2 800 5-5-5-15 1.9V BIOS SETTING
http://www.gskillusa.com/motherboard..._2gbnq_001.jpg
http://www.gskillusa.com/motherboard..._2gbnq_002.jpg
use 1.9v 5-5-5-15-4-42-3-11-7-13
EDIT.. OK I get errors with memtest86+ v1.70, when running them one by one in slot A1, using the recommended gskill settings, with each stick erroring at different points... I don't know how to interpret the results. Can I make any assumptions? Is there some other test I should run?
EDIT.. Don't know if this testing app is any good, but I ran it on one of my sticks and the system locked up after some time.. Trying the other stick now... http://hcidesign.com/memtest/download.html
EDIT.. Second stick with this app, I got a ton of errors, and it didn't lock up...
I got 972 of these type errors before I killed it:
http://i217.photobucket.com/albums/c...1/snap-102.jpg
EDIT.. I just put the two sticks back in, booted up, loaded up some programs and the system crashed after a few minutes of surfing stumbleupon with firefox...
