Well i've tried clockgenning it when it's loading at 0C and it locks up around 270 HTT. It did almost 3.4 Ghz screenshot on water so it should not be locking up like that at all.Quote:
100% sure! ;)Quote:
Originally Posted by wittekakker
@Absolute_0
U tried above 0°C, i mean around 10-15°C?
Nope. I have phase change and air cooling, and the air isn't going to get cold enough... in the dead of night last night coldest temp was 9.5 C.
Does somebody like this?
All cooledwith thermaltake BIG TYPHOON 37C load it is a OPTERON 146 CABYE 0540 FPBW.
http://img73.imageshack.us/img73/366...14624h26sp.jpg
It´s even for sale =) PM if interested.
Nice chip, though why did you decide on using the 9x multi instead of the 10x? Just curious.
Ohh, it does the same with the 10x but i tought using the HTT multi 3X and the fsb 333 Would be kind of perfect, 1000 is optimal and 3x333 is 999 so why not? :)
Sounds good, just wondering you see. :)Quote:
Originally Posted by Wiker
Have you tried with more volts?
the mobo won´t allow me.
My chip but it´s not stable,for 24/7 it´s 3000 with 1.475 vcore.
http://img513.imageshack.us/img513/2926/27000b3yf.jpg
I was playin with my Opteron 146 and here is results.:D
http://slike.slo-tech.com/17037.jpg
http://slike.slo-tech.com/17038.jpg
http://service.futuremark.com/compare?2k1=8878394
opteron 148 CABYE 0543 FPMW @ 1.6v, big typhoon.
32M Stable at 322x9 (2.9ghz)
http://img73.imageshack.us/img73/842...0mvload7dj.jpg
Just got a new one
Opteron 146
CABQE 0547 GPMW
Comp is in my dorm so no OCin yet, anyone heard of a CABQE?? I like 0547 GPMW because my 148 0547 GPMW does 3.1+ Ghz on water. So i'm hoping for good things.
Oh yes, and i got a replacement for my coldbugged 148. Thanks to Coop!
Opteron 148 CABYE 0543 FPMW 06xx batcher
My single stage is getting poor temps so right now i'm temp limited, but this chip has a lot of potential.
11x300 with 1.52 volts prime stable (kept going for over an hour before i stopped it), loading at +6C
http://img.photobucket.com/albums/v7...olute035/3.jpg
Suicide run, 1.63 volts, 3.62 Ghz, CPU was reading -12C at the time when i got the screenshot. Would easily go past 3.7 Ghz if i was idling below -20C i think
http://img.photobucket.com/albums/v7...Computer/3.jpg
Got the validation a clockgen click earlier http://valid.x86-secret.com/show_oc?id=67089
I also have a CABQE 0547 cpu ;)Quote:
amd opteron 146
but i have a GPAW rev..
http://img32.imageshack.us/img32/1588/cpu5kt.jpg
> thats my cpu..
despite...i can't oc it very good, because i have a crappy ZALMAN 400W APS power supply... and it does NOT have stable voltage rails...
max I reached (under air)
2.9Ghz @ 1,5vCore Max
(srry for my bad english)
What air cooling? What load temps? How bad was the Vcore fluctuation?
Sry about all the questions, but i got 3 more of these incoming from the same place so probably same or similar stepping.
btw here's my 146
http://img.photobucket.com/albums/v7...2818Medium.jpg
And i'm hoping for good things because my 148, also 0547GPMW, does 3.1 Ghz with 1.5v on my watercooling
my 148
http://img.photobucket.com/albums/v7...2814Medium.jpg
What air cooling? Zalman Pure Copper 80mm
What load temps? 50° max.. (i found out recently that the cooler wasn't mounted properly...now 40~45° max)
My vCore setting (in bios) is 1,450vCore
my Cpu is currently clocked @ 2,6 Ghz
my bios reports (hardware monitor) 1,4250vCore
but when I run Prime2004 (8 hours right now), my vCore is 1,375v average
(Asus pcProbe reports this voltage)
I hava a Zalman 400W APS ... and a ASUS K8V Deluxe..
someone said me, the voltage drops are due to the motherboard...
soon, i'll let repair my Msi neo2 platinum (nforce power)..
and i'll install a ThermalTake big typhoon...
(@ ebay, my cpu is reported to do 3ghz on air @ 1,5vcore max.. > so did I , 2,9 @ 1,475 vCore... some better cooling, ans i'll finish the job)
Seems like a good one then.
To me the question is: does it have cold bug?
n00b question, what exactly is the "cold bug"? What symtoms occur to the chip? Is it only when applied with DICE and vapo chill cooling? Sorry for the stupid question. I'll post a pic soon
I'm saving up for phase, but here is what I've got so far. CAB2E 0540FPMW
http://img43.imageshack.us/img43/4228/occt21vl.th.jpghttp://img43.imageshack.us/img43/764...raph9qd.th.gif
http://img43.imageshack.us/img43/454...core1wo.th.gifhttp://img43.imageshack.us/img43/526...lt126yq.th.gif
http://img43.imageshack.us/img43/711...05664gy.th.jpghttp://img43.imageshack.us/img43/807...05675ae.th.jpg
http://img43.imageshack.us/img43/219...05702fm.th.jpghttp://img43.imageshack.us/img43/882...05738hy.th.jpg
http://img43.imageshack.us/img43/876...05809sw.th.jpghttp://img43.imageshack.us/img43/135...05858yl.th.jpg
My opty under dice:D
i'm gonna buy Opteron 144 soon..
can u tell me wich steppings should i look for...and wich should i avoid ?
i see CABNE and CABYE are good overclockers;)...
IMO, CABQE is also not so bad :)Quote:
Originally Posted by tema
(reaches 2.9ghz @ 1.5vCore MAX)
(reaches 3Ghz @ 1.55vCore MAX)
(CABQE 0547 GPAW)
Next week there will come an Opty 146 CABNE 0530 APMW (thanks Mongoled :) )
Hope it likes DI :)
Got my opty few weeks ago, had no time to play with it, but when i started i was extremely happy, it has unlocked multiplier:banana: :banana: :banana:
and overclock extremely well got it to 3345Mhz under waterchill extreme watercooling :banana:
ho does it look to yee??
Almost forgot, it is
cab2e 0548 fpmw
ladyback, saving up for phase change with a CAB2E stepping is not recommended. It will almost surely coldbug.
brechtvm, that CABQE of yours is looking better than before. If you can do 3 Ghz with your 50C load temps, then surely it will do 3.1 Ghz on watercooling. I'm gonnna hopefully get to testing mine out tonight.
Ok, the dilemma for the hour....
I have finally recieved my first opteron 144 oem chip. Shortly followed by an opteron 148 oem chip. Now I have to decide which one to sell.
144 - CAB2E 0546UPMW
on temporary stock amd cooling, and stock volts, this guy is pretty stable at 285x9. I tempted fate by putting 1.55v on it on stock cooling, and it stayed below 45 C at load, sometimes idling below 30, pretty much stable at 325x9.
148 - CAB2E 0547GPMW
on temporary thermaltake venus 7+ cooling, I can run 290x10, 270x11, at 1.55 volts, but it spikes the temps up to nearly 60 degrees load, and never idles below 37.
I'm running a dfi ultra-d, and I'm gonna be running water cooling (2x120mm fan radiator), so the 148 may really shine after I take the heat away. It just really impressed me how low the 144 stays.
Also, I won't be going into phase change any time soon, just sticking with the water.
Which should I keep?
