Dude I am down, maybe even 4.5 lcc challenge for people with gimp chips lol
ehh f(l)uck it, 5ghz is good no holds, no limit on memory, vga etc. . . any cooling method?
sound good?
That's fine Don. It just for benching fun and something to keep us busy during the winter months. Other than ivy cpu capped @ 5Ghz, It should open for all hardware.
Yeah, I agree, make one without the limitations, that should be fun ( to watch ^^ ). :)
lets do 4.5 2001. not all can hit 5.0 on air.
^4.5 it is then, and no limitations on boards or hardware used.
this format looking ok?
"Inspired by Hondacity:up:
3DMark01 4.5Ghz Ivy LCC
1. Screenshot Requirements:
- 4.5Ghzghz +/- 1mhz
- 3DMark01 main window with details tab
- cpuz: cpu tab + memory tab + motherboard tab + gpuz
- no limitations on hardware or cooling
2. Ranking requirements (use following format):
Username - score - multi x blck - vga clocks (core/shader/memory) - ramspeed(xxxx.yy)mhz - ram subtiming(tCL-tRCD-tRP-tRAS-tRFC-CR) - Motherboard model - ram info/chipset/vga model - cpu/ram cooling
ZenEffect - 128,452 - 45x100 - 900/1800/1100 - 1333.8 - 8-11-6-19-232-1 - Gigabyte UD5 - Kingston 2333mhz 2x1gb/BBSE/Asus GTX 580 DirectCuII - stock air"
I directly ripped it from Honda's post;) hope he won't mind.
Can you guys think of anything else we would need to add?
Awesome L0ud:up:
I'd be down for that too.
Hey guys, sorry to interrupt the current topic discussion, but I wanted to let everyone know that I will not be submitting to HWBOT an RDRAM Memory Clock...
Have had problems within my immediate family lately, also very busy with school. Homework takes priority over overclocking.
Got a lot of stuff I need to mail out too.
No biggie, life > benching especially when dealing with family.
Hope all is well Sam.
Well I ended up cutting the night early as all of sudden I was having "AE" boot code and then a black screen after a few 01 runs, luckily I was able to nab a decent 01 run. . .
http://i.imgur.com/tC83o.png
the next run had higher cpu clocks but much more inefficient as I don't think I had enough v's for the memory clock on the vga card
http://i.imgur.com/RXXcc.png
after a bit of googling AE is legacy boot device ID, most people were able to resolve this by removing DVD drives and or hard poweroff of the psu, both things I did not do as my internet was down:shakes:
No worries I will revisit tomorrow as well as some 03;)
loud you want my slim Tek9? I never used it. jsut send it back when you are done.
http://img14.imageshack.us/img14/193...ember1st20.jpg
Insane CPU Mafio, well done! :up: :up: :up:
I understand! :)
Sort everything out and I hope to see you back again soon. :yepp:
hey guys what is a good LOD for the GTX 580 3-5ish for each sub test?
I don't remember what lod settings I used the last time I benched the 580 and 01 but its best to test it out yourself since different setups produce different results. If you dont have the time to test each lod level with each sub test then I would try 2-3 for quick runs.
Thanks MTP04, sorry I was not able to get a 580 sub in for the team cup, no internet connection all day. It has been up and down the last two days.
I will give 3 a quick spin on all subs. I was able to almost break 140k with no LOD/D3D so I am hoping with those tweaks and a non bugged CL I should see about 148-150K
I think you should try a bit higher, around 5, at least for Nature.
^Will do captain
i just ran 3 on all 1-7 i didnt run any order just 1-7
