Hi guys!
Last night I thought that my vcore in bios was at 1.30 but it wasn't... It was defined at 1.25V! :hitself:
It ran 10 flawless hours of prime95, no errors what so ever, but now I arrived home and windows had crashed :mad: I have Vista SP1 x86 installed and not quite sure why this is happening :( When I'm at the computer everything is ok...
Could it be the OS? Sometimes I really hate Vista and want to go back to XP Pro SP3... Maybe I get this stupid crashes solved :confused: :rolleyes:
Now I made some changes in bios. Here's how I have it:
JumperFree Configuration Settings
AI Overclock tuner: Manual
CPU Ratio Setting: 8.0
FSB Strap to North Bridge: 333
FSB Frequency: 450
PCI-E Frequency: 101
DRAM Frequency: 1081
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: AUTO
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
AI Transaction Booster: AUTO
CPU Voltage: 1.3250
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: 1.54
FSB Termination Voltage: 1.24
DRAM Voltage: 2.1
NB Voltage: 1.30
NB GTL Reference: AUTO
SBridge Voltage: 1.20
PCIE SATA Voltage: 1.60
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
Advance CPU Settings
CPU VID: Disabled
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
Do you have any suggestions to my Vista crashes?
And how about this bios settings, is it ok or do you suggest something?
