You can buy Lian Li mesh and cut your own holes, smiliar to bitspower mesh. But I believe this is just entire 3x120 top panel from LL.
@pociej, h20xide and aerial
Looking like the original from optional LL top
I think thats what he means by 'modded', replacing the stock top with the 3x fan top
Thanks guys! For sayin that it really really looks like an original T-LF37B-2 Top,Quote:
except of course for the 25mm fan spacing :D
The original fan mesh i bought from a friend
@anthony8659: amazing rig boss anthony! :up:
Triple pumps?!? :confused: Three loops or just one hellacious loop?? :shrug:
i wayt of my last bitspower parts , its no problem ..
@oXcoRe : wOw!! triple pumps
Wow triple d5's.. 1 loop ?
well here is my first water loop ever on my old trusty q9400..
its pretty ugly after what i've seen here but im not rich and its my first time !
this wc loop costed me 450$ total.
well received installed and tested my for leak , now my system is up and running ambiant temp: 31 , CPU: 41 GPU: 28
Load temp CPU:50 GPU:48
i am using the CM Sniper and i wanted to use the top for my rad and keep the 200mm fan , to do this i ad to do some modification, i made 2 hole and i ad to cut the plastic from the top to make it fit, that was the hardest part of the job , after GPU.... WOW EK information are pretty much non existent and it look that it as been made by a chimp
Installed system working order
http://img812.imageshack.us/img812/1674/p4210110.jpg
:shocked: Around $600 just on pumps, seems like you ended up spending more on watercooling parts then you did on actual hardware :rofl:
Simple mistake, I never read his specs under the pics I just assumed because its beyond me why he's not even running sli! :shakes: Trust me though, bitspower goodies add up $$$
& you would think watercooling is just for the bling factor on top of good hardware, but there are plenty of people who really cheap out on their watercooling parts because they can barely afford it. Don't ask me why they bother...
@emoners
big thanks sir http://www.forumsextreme.com/images/sHa_wink.gif
significant update to build: 'That's no Moon'...see sig
mountainmods ascension, so wire management a struggle, but coming along
http://i627.photobucket.com/albums/t...g?t=1303861393
http://i627.photobucket.com/albums/t...g?t=1303861502
http://i627.photobucket.com/albums/t...g?t=1303861535
http://i627.photobucket.com/albums/t...g?t=1303861553
@mwlhrh
Love your MM Ascension. Im getting a MM Ascension case this summer. Gonna use ur build for cable management help! :D
^ This. I remember NaeKuh having similar problems :p:.
new GPU RL, new tube and new coolant!
http://fotos.subefotos.com/a06498c4c...8d638fb72o.jpg
http://fotos.subefotos.com/5a6d8d360...dddf7b307o.jpg
http://fotos.subefotos.com/c03c2a715...343e0b673o.jpg
A small request ... please keep chat to a minimum. We're getting back to more comments and fewer pics. Feel free to use the PM system to ask questions.
