Thanks coop. :)Quote:
Originally Posted by coop
Wish I could do some 3d benching on it, but I'm lacking a graphics card at the moment. Currently using a PCI Radeon 7000 64mb. :p:
got a 146 CABYE 0540FPMW too :toast:Quote:
Originally Posted by Questarr
highest I primed yet was 3050 MHz on a Freezer 64 pro
and dont bother about those low voltages the smart guardian displayes from your tagan psu, I have low voltages displayed too, but a measured them with a multimeter and the voltages are fine
Thanks. :)Quote:
Originally Posted by Jupiler
However, my board is maxing out at 320 MHz ... I am not able to test any MHz further. This one would run 3250-3300 MHz Prime95 easily. Also nice suicide runs far above 3.4 GHz should be no problem. Tweaked the ram settings to hell but no boot beyond 320 MHz. :(
anyone in here have a msi neo4 platinum w/ a opty 148? cause i need some help. my opty can do 2.8ghz on stock volts using clockgen stable in windows. but when i set anything over 238 mhz it results in no posting. i can only manage 237 mhz for an overclock of 2.6 ghz. i know its not my rams either. my ocz gold edition can do 260 mhz fine.
nice:) What were your vcore and temps when you primed at 3050?Quote:
Originally Posted by Aerosupra
Not to bad to start, I still need to prime overnight but 3d stable.
This mobo is a :banana::banana::banana::banana::banana: over 250MHz on the ram, going to try that now...
http://s88500732.onlinehome.us/amd at 2999.png
http://s88500732.onlinehome.us/3dmark.png
lol 0,080v thats good!
just got my Opteron 148 from Monarch this morning, CAB2E 0547 GPMW batch 0112, currently burning it on the stock cooler. Results soon.
EDIT 1:
Priming at 2.90 Ghz with 1.40 volts on the stock cooler, 52C load :toast:
i was expecting a crappy OCer since we're out of CABYEs, maybe some of the CAB2Es are competent.
http://img468.imageshack.us/img468/5...kcooler8pn.jpg
Still on stock cooler
http://img410.imageshack.us/img410/3...kcooler1gr.jpg
Very nice chip Absolute. :clap:
Impressive to have stock cooling. :fact:
When it puts it under its WC? :slobber:
Until soon Friend
Thanks, i'm burning it up on stock cooler. Watercooling is being sold, i'm moving to a Chilly1 single stage. The chip was OEM overnighted from monarch, seems week 47 is alright so far ;). Gonna burn it all day, and then phase it, hopefully the CAB2E coldbug isn't too bad for my single stage.Quote:
Originally Posted by SET
Nice results :)
Got a CAB2E 0547 GPAW the other day .. I hope it OC´s as good as yours.
As soon as I get the Expert mobo I´ll give it a try. My old one is acting funny after beeing a part in some DI-action.
I just got my 148 from Monarch on Wednesday....
Same exact stepping as yours.
You are the only 1 I know that has one of these.
Mine doesn't seem as good as yours, right now it's priming at 2972 @1.52v, 48c load.
muzz, what cooling, and what batch number?
TT BT hsf
I am 95% sure it is the exact same batch(didn't write that down, I only looked at the batch for a split second), it's definitely the same exact stepping.
I think I'm gonna install my Zippy 500 in this machine ( it's my HTPC, so I have to quiet the fan though, I'll adjust the voltages when I have it open), to see if it's better than my powerstream420( I believe it will be, but I don't know if it will help).
Looks like you have a good chip there, mine did about 2.8 at stock vcore, I know I was priming for almost 4 hrs(i shut it down) 2830@1.45.
BTW does anyone know of a windows proggy that will allow me to change vcore?
I cant with clockgen, or crystal or gcpuid etc. with this Opty...
thx
m
That is good to see Absolute 0. I had a 0546 but different stepping that would not do that. Hopefully some of the best ones are yet to be sold.
ok guys, small update, ran SP2004 a little longer
5+ hours, 2.95 Ghz with 1.40 volts, stock cooler cooled, normal ambient temps around 69F.
http://img356.imageshack.us/img356/2...ockcool9gn.jpg
I really can't prime much higher, it gets too hot 54C when i increase the voltage by a notch. Did a screenshot at 3113 or so with 1.45 volts... not that much, i think it's just begging for more cooling :).
just bumped up the volts to 1.50, got off a SP1M at 3063 Mhz and this screenshot
http://img80.imageshack.us/img80/8141/3180mhz3uh.jpg
yeah Aboslute, pronlem may be a cold bug with these chips, I hear most Cab2E have it. I wont be putting this under the prommy, as this is my HTPC, so it must be quiet!!
I may put this under water, but I'd have to dig out that stuff and build a hold down plate(designed for AXP), which is no biggy.
GL
m
U can use Right Mark CPU Clock Utility, its a wicked program. It does lots of things. I have it set to dynamically change my CPU speed/voltage depending on load :). Its like CnQ but without the heartacheQuote:
Originally Posted by muzz
:toast:
I tried that, and it didn't work for me....Quote:
Originally Posted by mongoled
Maybe I didn't have something set to auto in bios?
I dont remember.
Thx
m
i have a 148 CABYE 0528 GPMW and a i can´t pass 2870 mhz Prime or go stable.... why? my opty is bad?
I think "my problem is the Expert"
ok everyone, bad news about my 0547 GPMW 148, it has an insane cold bug, locks up at 260+ HTTs even when at positive temps in windows. Expect to see it in the F/S section where it will make some watercooler very happy.
absolute: get 1 thing straight
vcore in bios isn't same as in windows....
always report the one from bios!
Technically the one in the BIOS is wrong as well and i should use a DMM to get the right one. But everybody goes by the windows readings so i don't want to go way out of my way to deviate and confuse everyone.Quote:
Originally Posted by TEDY
I had a feeeling that was gonna happen considering all the press the CAB2E cold bug gets...Quote:
Like I said, mine is for HTPC, so quiet/good OC is a bit more important that all out OC, so 3G on QUIET air(TTBT) is pretty good!!
Not for you though...:(
