Originally Posted by
cadaveca
well, you must undersatnd that by default the board only uses half-phases, not full, so possibly without driver, you can never get proper load-balance. But not to fear...I have not isntalled drivers from ASUS on most recent board...just simply used Intel's .inf's for chipset and SB, as ASUS driver CD's have been lacking for eons... even just using Intel drivers, I still have the problem. It could simply be something caused by X38 driver...I did not see this problem when I played with X38 and DDR3 tho(was not an asus board tho, so no EPU..)
To be honest, dealing with the problem by buying new cpu, or getting different board, is the only solution. It's a low-level driver issue caused by hardware implementation...change the hardware, and the driver is not a problem.
PWM = Pulse width modulation....meaning the voltage supplied to cpu from PSU is not constant..it's pulsed. It could be possible that due to how current is "shared" bewteen phases, and how this is regulated that is the issue...EPU could NOT be the problem, but maybe problem lay in PWM, and reading given back to EPU by PWM created teh loops...i dunno. I lack the expertise in this area...too many SMDs in circuit that do not have proper documentation for the public.
