c'mon man, get more monitors! ;)
or get more time to resize the pic and link them to frickin' large ones
theres a thread about this problem already...
Wow these rigs are awesome.It's inspired me to give watercooling a go I've ordered most of the gear i will need except the vga block.I was looking at the ek full covers blocks.Whats the difference between the EK-FC8800 GTX and the EK-FC8800 GTX - Acetal one's see through and one's not which one performs better and it low restrictive???
cheers
Hi all!
After about a month of checking this Gallery i decided to go for proper water cooling (i've had Zalman Reserator1 which is kinda joke)
I've got some ideas here and this is the result. Im not using chipset coolers because im awaiting new 45nm CPU so i'll get new mobo with that and im gona use chipset coolers than.
Please let me know if there is something that you would not use or do or do somehow differently
System specs:
Case Antec PW160
Motherboard Abit AW9D-MAX
CPU C2D X6800 (ES) @ 3.793 didnt really try how far it will go yet
GPU XFX 8800GTX XXX Edition 630MHz jadro 2GHz pameti (no overclocking yet)
RAM 4 x 1Gb Team DDR2 PC2-6400 Xtreem Micron 3-3-3-8 @ 800MHz(no overclocking yet)
PSU Corsair HX620W
Sound X-Fi Xtreme Music
2x Raptor Raid0 Stripe16
Cooling:
CPU block Swiftech Apogee GTX
VGA block D-TEK FuZion GFX
Pump Swiftech MCP655-B
Radiators Swiftech MCR-320 Quiet Power 3X120mm with 6 fans Noiseblocker BlackSilent XL1 first 3 @ 7V second 3 @ 5V
Reservoir Cape Coolplex Plexi 25
Tubing Tygon R3603 1/2in. ID
Coolant FluidXP+ EXT Blood Red
steffen, are these rosewill fans ?
Some pics of my final build :)
http://img391.imageshack.us/img391/5346/46578055fv7.jpg
http://img391.imageshack.us/img391/239/46578038jx0.jpg
http://img391.imageshack.us/img391/5449/46578058kv0.jpg
http://img391.imageshack.us/img391/6753/46578072kx7.jpg
Loop order : EK Res 150 - MCP355 with Petra's top - EK-FC8800GTX - Thermochill PA120.3 - FuZion - MCW30 - Back to EK Res 150.
Looks great ? :)
My workstation/gamestation/media server/file server...
http://i47.photobucket.com/albums/f1...18resize-1.jpg
http://i47.photobucket.com/albums/f1...07resize-4.jpg
http://i47.photobucket.com/albums/f1...0011resize.jpg
http://i47.photobucket.com/albums/f1...12_2resize.jpg
http://i47.photobucket.com/albums/f1...02resize-1.jpg
http://i47.photobucket.com/albums/f1...17resize-1.jpg
http://i47.photobucket.com/albums/f1...0058resize.jpg
http://i47.photobucket.com/albums/f1...0061resize.jpg
Dark Prodigy one of the best setups i have ever seen. How much did your wc components + case cost to you ?
Better water flow :D
http://img465.imageshack.us/img465/3...olz2pq9.th.jpghttp://img182.imageshack.us/img182/1...olz1tf0.th.jpghttp://img511.imageshack.us/img511/3...olz3nd2.th.jpghttp://img401.imageshack.us/img401/6...olz4hb7.th.jpghttp://img295.imageshack.us/img295/7...olx1nm0.th.jpg
http://img408.imageshack.us/img408/4...olx4rv7.th.jpghttp://img527.imageshack.us/img527/9...olx3dk1.th.jpghttp://img245.imageshack.us/img245/6...olx9ca7.th.jpghttp://img72.imageshack.us/img72/970...olx8ge3.th.jpghttp://img340.imageshack.us/img340/8...olx6jh1.th.jpg
Temperatures and performance are compareable with Fuzion WB ;)
But new Viscool CPU WB is very cheap , you can order it here (Only 24,- € or 29,- $ ) :up:
Dark Prodigy...great looking job!
Dark Prodigy what pump is that, an Eheim?
Nice rig you got, I think it may do very good in distriuted computing. :)
Click the link in my sig. :D
Looks like the 12 volt Eheim 1046.
