Thanks guys :)
Originally Posted by
Phaseshift
worklog screamer?
Unfortunatelly not here - PCLab
Lu(ky
Nice Screamer is that Feser F1 red, or distilled with dye?
It's AquaComputer Double Protect Ultra coolant. Red of course.
Johnny87au
wow screamer the res/pump combo looks mint! Is this a new build because you've used that coolant in a previous build..
Yes, it's my new build in PC-A05. Previously I had PC-V2010, so... from giant to dwarf :D
But setup is almost same. Previous project's here: gallery
She's absolutely amazing. And I'm not just being patriotic ;) :up:
Dr.Joe
The Lid is missing, but other than that ist a case :D
and the Radiator:
still a work in progress? or you have completed pix hiding somewhere?
Dr. Joe's pics are working for me ... holler if they aren't showing up for anyone else.
shazza
The pictures work great...
I was asking for more or a work log ;)
I do not like quoting pictures
I do have a mini-worklog on bit-tech: http://forums.bit-tech.net/showthread.php?t=179557
the last picture with the radiator is pretty much status quo, i added the harddrive and put on the lid, and it sat on my desk like that for about a year now. :D
Other projects are keeping me away atm, but i will definitely finish this one. the pump @full speed is driving me crazy (~50cm distance to my ears, and nothing in between)
@Dr.Joe: that's a pretty sweet build... was about to ask what case you're using, but then you posted your worklog link. will you be adding a graphics card in there? from the last pic, it seems that you could still (maybe a low profile one)...but then i guess you have to re-mod the backplate.
As a big fan of wee systems I'm enjoying this tremedously!!! :clap:
So nice but no window to show it off!! :shocked: :shrug:
stevedawg, nice & simple :) I, personally, prefer 700D over 800D exactly because it has NO window - looks cleaner and allows you to make your own window of desired shape & size :up:
BTW, is that an external HDD next to the case in the second pic ? If so, what brand/model ?
Thanks everyone. A window is in the planning but as of now is put on hold.
@ Tigris: Its an old (4 years old or so) Lacie.
http://www.lacie.com/support/support...t.htm?id=10096
stevedawg
Thanks for the link ;) Although it is quite old, it looks very classy :cool:
steve, what reservoir is that? I thought reservoirs like that only existed for the MCP350/355/35X
ScottALot
http://pccasegear.com/index.php?main...ducts_id=14351
Needed auxiliary cooling for the gpus did ja!! :ROTF: Nice looking layout
Take it the Tt is cooling thr mosfets??
jedihobbit
Thanks! Yeah, those 580's get pretty warm, but I think I'm gonna pull that fan though. I don't think I really need it.
And yes, the Tt is cooling the mosfets.
Water cooled HD6990+6970 align perfect
Very powerful setup you got there!
