Originally Posted by
cadaveca
I'm sry for this attack, as that is all I can call this post of mine, safan80, however, once again, you fail to read my post completely...my settings have already been posted in this thread.
Again, in the last post, which you just quoted, has yet ANOTHER set of settings that show this behavior...I don't know how to epxlain that everything was set at default other than those things I mentioned any other way...
And really now, do you seriously think I would be so lax in my overclocking to not have already tried EVERY SETTING COMBINATION to eliminate the problem?
Obviously you do, and I must then be aware that you are too quick to judge how I overclock without even knowing what parts I have...you simply state"I don't have it, so it's a non-issue", without first facing the real variable between ou rsystems...the cpu.
NO 2 CPU's will draw the same power. A L737B with 1.25v VID should draw about 75A-80A @ default speeds. Notice I said should...ask Fugger if the two cpu's he got with sequential serial numbers clocked the same....I bet you can already guess his answer...NO!!!. They were close, sure...but not exactly the same.
SO, let's keep cpu in mind....
what's differnt between them? Say myself and GAR...him with G0, me with B3.
OK, so stepping is different.
But what else is different about those cpu's?
How they clock?
:stick:
NO!!!!
How much power they draw?
YES!!!
So, having spent some time with GAR on this issue, and about 72 straight hours digging into it, I could find no answer to remedey the problem.
I changed each and every cpu setting, tried every bios ever released...could not get rid of the problem over 1.477v real(read with DMM).
So, I went and bought a new cpu...
Popped in new cpu, issue was gone.
cranked up the clocks, and volts...issue remained gone.
Tossed my pot on the cpu, cranked up the voltage to extremes...the problem came back.
New bioses have come out(8&9-series), and not one of them made any difference.
So, as much as you want to blame this on something other than the board...there is no such possibility. Now, what part of the board that causes the issue...EPU most likely...why...well...I dunno.
Other than that, unless you can actually duplicate the issue iwth the cpu's you have, I highly doubt you'll be of any help...it's directly related to power consumption, and some CPU's just simply quit scaling before they ever reach the amperage required to trigger the issue...
but if you'd like to try, here's how to attempt to replicate:
set cpu @ 400x9, 1.525v.
load up prime95 v25.5, run four threads of small FFT.
Open task manager, and verify on the process tab that prime95 is using 99% cpu time.
let prime run for 20 minutes...check task manager again.
If prime is still continuosly loading @ 99%, then up voltage by .025. Repeat prime test, and verify cpu time in task manager process tab. Continue to repeat until you see that prime95 does not get 99%...if just getting close, it will take 20 minutes or so(depending on your cooling, and how long before you reach stable coolant temps) before prime95 will loose just 5% cpu time.
As you get higher in cpu consumption, System process will "steal" more cpu time from prime95...until you get 75% cpu time w/ prime95, and 25% with system process.
I will re-interate...XBX2, P5WDH, P35 Neo2, P5K, 965Dark all do not exhibit this behavior...only Maximus Formula does. I cannot verify whether the non-SE parts do as well...I do not have one of these boards. But for 5 boards to show no problem, but one does, really points towards the board.:fact:
