Yes it's useless IMO. If you have a copper base like the freezer has it will work great if you have it installed properly. Mine is facing up towards exhaust fans, one on top of case and at back, plus the psu is sucking it out too. It doesn't clip too tight either on my DFI when you take the IHS off, so no worries about crushing the core. I cut my damn fingers trying to cut it off though heh. Had to use a thin shaving razor but once i cut through it was easy to wiggle off with my finger.Quote:
Originally Posted by GOESA
