Haven't tried the x8 but this one will do 480 :)
Single G92 GPU stock cooler
3DM06: 18,217
http://service.futuremark.com/compare?3dm06=4432286
http://img2.freeimagehosting.net/uploads/82d3d663e1.jpg
3DM06: 18,217
does i have problems in my mobo?
i have a kit 2x1g crucial balistic tracer pc 8500 with abit ip35 pro
but i doesn't work when i set ram run more than 570 Mhz
my pc couldn't pass the welcome screen
someone plz help !
how much voltage are you using on your memory?
what bios do you guys reccomend for a Q6600 gO
Hey guys, anyone ever get a performance level of 4. I put some cellshock back in (2x1gb d9gkx) and have it at 335x9 and the ram at 2:3 at 500mhz 4-4-4-12 and I got a performance level of 4. Seemed really low I thouhgt. Is this just from being on the 1066 strap.
I'm getting ready to build a new system? I want to get a QX9650. Is the Pro the best way to go or would the Quad GT be better? Planning on 8 gig of G Skill 1000 for memory.
@Ace-a-Rue
i try vdim from 2,1v to 2,45v and add some votage at CPU VTT; MCH;ICH;ICHIO too but it's still fail(stop at welcome screen)
and can u tell me what's "DDR2 Reference Voltage" ; " CPU GTLREF 0&2 " ; "CPU GTLREF 1&3" ?
should i change them ?
@Ace-a-Rue and the rest of you 1 question!
Please reccomend me the settings for the following categories for 9 x 400 = 3600MHZ DDR2 800MHZ 1:1 Ratio...Thats all I want...The chip will boot at 3600mhz but prime 95 fails within 2 minutes but I have been running it at 3400mhz 1.5V set in bios for 18 hrs prime 95 stable and a week of general use.....I know its hard to give the exact settings but with the speed I want at the low 400 fsb I thought it might be easy for you guys to guide me the right way.....
L737A822 10/17/07 Q6600 gO STEPPING
uGURU Utility > Voltages Control
CPU Core Voltage _____
DDR2 Voltage _____
CPU VTT 1.2V Voltage _____
MCH 1.25V Voltage _____
ICH 1.05V Voltage _____
ICHIO 1.5V Voltage _____
DDR2 Reference Voltage ____
CPU GTLREF 0&2 ____
CPU GTLREF 1&3 ____
My temps are not an issue and the pwn area runs cool....I am using 16.04 Bios
Thanks in Advance :clap:
i am not a prime 95 fanatic...i think anything over one hour is overkill...it's a waste of electrical energy to prove what!?...nothing, except you are P95 certified....many posters have said, i am P95 capable but a video game kicked back to the desktop or folding failed after 'x' hours.
considering vdroop for idle and load you will need around 1.57-1.58 vcore set in the bios to possibly accomplish P95 at 3600 mhz...i use wPrime (1024M bench part) in place of P95...if i pass that, i should be able to do any bench or everyday tasks.
here is my Q6600 at 3915 mhz which was wPrime capable...you can try those voltages for 3600 mhz to see if that gets you one hour of P95....adjust from there up or down!:)
once you receive the board, confirm it operates normally and then do my heatpipe mod.
I'm not Ace but I hope my info here will be useful to you. I'm using 16B03 BIOS. (note: 16B04 default is a little different and temp reporting is way off for me that's why I'm using 16B03). Anyway, using similar hardware as yours at 3.6 GHz, I have:
FSB = 400
Multi = 9
DDR ratio 1:1
Vcore: 1.47V
MCH: 1.33V
The rest are at default.
At 3.8 GHz, I have:
FSB = 422
Multi = 9
Vcore = 1.58
MCH = 1.37
ICH = 1.09
The rest are default
Has anyone tested for the highest FSB on a yorkfield with this board. Either search is dumb or I am.
It's looking as if I might take this over my 780i upgrade.
my 9650 maxed out at a stable 460...i could reach 465 but it was flaky...i think it is a FSB wall for the cpu since i get the same results on the DFI X38 board...plus, it was the same way on abit's IX38 board....that was under air...other types of cooling could achieve better results.
hey guys..how about voting "excellent" for this thread...i think it is well worth the "5 star" vote...other threads with less participation are rated with 5 stars...just go to the top of this page and vote under "RATING"
I voted 5 star back when I first joined in June; what's it rated at right now?
Oh, and Happy F'ing New Year!!! :D
The mosfets on my board deffinately aren't level with each other. So, since I made a waterblock for them, should I just use the stock brown thermal pad from the crappy factory aluminum sink, or just go with a thick dab of MX-2? Always wary on using TIM on chips that it can squish out over the sides & possibly cause problems.
