Hello,
I just put my conroe system back together a few days ago and its been running great, however the last 24 hours something strange has been going on?
I was sitting doing my surfing and the screen went black, almost like the power-saving kicking in any I wiggled the mouse and a moment later the picture came back?
Just a few hours ago the same thing happened but this time the screen stayed blank and I had to restart the machine.
Upon reboot it went:
BEEEEEEEEP . . . . . . . beep, beep, beep (thats one long beep and three short beeps) then switched off again, then rebooted and went all the way to windows.
What do these beeps mean please?
Once in windows I had the feeling that something wasn't quite right so I unistalled the drivers and tried the newer versions (CAT 7.8) however things still seemed a bit sluggish on the desktop so I opened CPU-z for a peek. . .
http://img502.imageshack.us/img502/4...irdpciedd8.jpg
It seems my PCI-E had set itself to 1x which is something I did read about 6 months ago but it never happened to me before. I restarted the machine a few times and it didn't go away, I had a look in BIOS and everything seemed in order. I then decided to shutdown the machine and give it a minute to rest. Upon reboot the PCI-E setting had corrected itself (back to x16).
I've used this puter for 7 months at least and never had this happen before. As I said I did rebuild it a few days ago and added in a Creative X-Fi XtremeGamer but apart from that nothing has changed?
I'm running:
ASUS P5B-Deluxe
Core 2 Duo E6300 : 2800MHz (7x400)
Crucial tenth anniversary sticks (2x1GB)
Powercolour 512MB Radeon X1950XT
Antec Truepower TRIO 500w
All the volts are on manual/minimum except vCore which is 1.3250v and NBCore which is 1.45v (purple).
Its been ok for the past few hours and I have since re-seated the card.
I know this has happened to people before but I cant remember the fix? should I change my PCI-E Freq from 100Mhz to 101Mhz or what?
