stuck on evap...and mower.
Right on every point there man. 2.1 would be the max I would try if the newer ICs are in place.
By the way, I toilet at air 1:1 to no runmc that I was going to make sure the ones I had would run the numbers he wanted. So far 1:1 with this POS processor I could only validate to 524 or 1048DDR. Not sure that would help him but on second thought they might have since he was under phase and I was airing it out. Think he was mostly unable to 'boot' at all without C1. Dang it. :yepp:
Originally Posted by
kitfit1
You'll like em. Running the 9600 Flex myself. Even though mine are the 2.35v versions, they only need 2.23v to run at 614mhz. If yours are the new ones, don't go shovelling 2.3v+ into them. The newer ones are different IC's and run at a lower Vdimm.
Perhaps "cutie's" got his mouth stuck on that nice cold evap you sent him :D
