that snail with tail case must be an absolute nightmare to watercool, but good luck nonetheless
BIP 120s
Yea they look like BIX's... BIX with a Noctua fan *shudders* :(
Do they push a lot of air?
well ive been browsing these forums for a year or so but i didnt think my rig was worthy of posting untill now, i installed my first water loop ever yesterday :)
so heres my baby :
http://i57.photobucket.com/albums/g2...t/DSCN3005.jpg
http://i57.photobucket.com/albums/g2...t/DSCN3006.jpg
this was my first build as it was initialy put together by my bro and i just did upgrades like ram and gpu, but i ripped the lot out to fit the watercooling and started from scratch
comments welcome :cool:
evga 680i-e6300 @ 3.15- 2gb balsitix 5300- 8800 gtx- ocz 700w- 2x 200gb 7200 raid 0- modded antec p160- belinia 22w
thermochill 120.2-swiftech ddc -apogee gtx -dd filport -fesser 1
better pictures coming when i get my uv cathode
stinka
That's not too bad at all, good work there. I'd consider trying to shorten up the tubing so the pump is closer to everything rather than sitting on the bottom like that - perhaps mount it above your HDD bays? Shorter distances will mean less impedance. I'd also go Pump -> Rad -> CPU rather than Pump -> CPU -> Rad, it'll give you slightly better temps.
well here is my1st post inthis section :)
Something i made up my self hope u guys like it :)
http://i146.photobucket.com/albums/r...Picture017.jpg
http://i146.photobucket.com/albums/r...Picture016.jpg
http://i146.photobucket.com/albums/r...Picture018.jpg
http://i146.photobucket.com/albums/r...Picture020.jpg
http://i146.photobucket.com/albums/r...sz_topview.jpg
http://i146.photobucket.com/albums/r...Picture015.jpg
Oh you lucky bastard, that is one very, very sweet rig there. What's in the loop? Looks like dual PA120.3s, am I right?
that looks like dual triple 120mm BIX rads there, look at the fan spacing, they're touching each other, Thermochills have a little gap between each fan. Swiftech's fins are less dense so it must be a BIX in there
Cheers guys :)
Well its a dual loop set up.
1st setup - res-> pump-> rad-> cpu-> res.
2nd setup - res-> pump-> rad-> gpu-> sb-> nb-> res.
As for the rads there are Hardware Labs Black Ice GT Stealth 360
@customss i really like your external WC box, really nice work..:up: i would like to see more pics of it, you would not happen to have a work log or something in some other forum.
@stinka what additive do you have in your loop..lol looks little bit like blood.. anyways looks freaking awesome to me..
and both of you guys :welcome: to XS
Here is my entry into this sticky. Just finished putting together a rig in a modded G70 case.
The front:
Attachment 61825
The usual 3-hole fan mod on the top:
Attachment 61826
Two more fan holes cut into the side:
Attachment 61827
The guts of my rig:
Attachment 61828
And the brand new X2900 XT 1GB in all its water-cooling glory:
Attachment 61829
I really have to say that xtreme systems really has given me quite a bit of inspiration for this build. I have learned quite a bit from all of you. Thanks! :up:
Finished her last weekend after about 4 days of putting it together, most of that time spent making it look nice.
Specs are as follows:
evga 680i motherboard.
Intel e6600. oc'ed to 3.4
evga 768mb superclocked 8800gtx.
4gb g-skill memory.
3 500gb samsung spinrite sata 3.0 hd's.
2 250gb seagate barracuda sata 3.0 hd's.
silverstone st1000 psu,1000 watts.
thermaltake mozart tx case.
swiftech ultra water kit with stealth full cover vga block.
operating pretty good so far, 11713 on 3dmark. I have orthos but have yet to let it run for more than about 40 minutes. No errors so far. Highest temp I have seen on cpu so far was 55c. and that was running orthos and doing other things at same time. Highest on gpu is about 50c also. Both idle about 38c. Open to any suggestions. Will post pictures. hope they work.:)
this thread has been hoppin lately with lots of cool new pics
meatpod sweet rig, though i should mention i am biased toward the G70 'cause i have a black one modded with the pa120.3
http://img55.imageshack.us/img55/746...30threems4.jpg
Shot with Canon PowerShot SD200 at 2007-07-18
http://img441.imageshack.us/img441/8...r830onelj9.jpg
http://img412.imageshack.us/img412/2...r830twoal4.jpg
Freaking awesome job there lowfat :D
Aye Lowfat that's a nice setup. Please tell me that my eyes aren't seeing zero clamps on the tubes though right?
http://i29.photobucket.com/albums/c2...r/CIMG0904.jpg
http://i29.photobucket.com/albums/c2...r/CIMG0898.jpg
http://i29.photobucket.com/albums/c2...r/CIMG0905.jpg
My setup.
Ek blocks on cpu nb/sb mosfets
Dangerden on video cards.
2x 3x120 radiators.
Striker Extreme
QX6700 @ 3.6
Gainward 8800 ultra sli
2gb Dominator 6400
2 x150gb Raptors
Sb X-Fi elite pro
