@ Ace and NFC, Outstanding builds all around, very clean and outstanding attention to detail. :up::up::up:
It's the LANCOOL PC-K7B. I just stuck one of their drive bay thingies in the front. It didn't go in actually--I had to file the front panel down a bit (just be warned.)
I actually like the case much better than Lian Li's aluminum versions because it is solid and doesn't vibrate. :up:
awesome build guys!!
I second that
Hi guys, this is my first post : )
Got bitten by a water cooling bug few months ago and here I am :D.
http://upic.me/i/9w/3a101.jpg
http://upic.me/i/23/5bb04.jpg
http://upic.me/i/eb/xb307.jpg
http://upic.me/i/oi/x8z30.jpg
Whats going on with the PSU there?
Not greatest water cooling plan, if you have such gigantic case, and still need to use psu extender. Unless it is intended and you like how it looks.
@h20xide and aerial
Many thanks for your comment ;)
Previously I put 2 systems in the case (there used to be Gigabyte H55N in there) and 2 PSUs to power 3 GTX480 (now there are 2 GTX580).
The H55N was placed in the bottom of the case so I needed the extender.
I leave the extender there as it is for now as I might try to put back the H55N and another psu back again : )
Not sure whether it is against the rule to post one more pic but this is the previous system :D. Pretty crowded huh?
http://upic.me/i/17/dsc04447.jpg
Nifty =)
Do you mind resizing them?
Here is one I did today (needs a bit more work but I am done taking pictures):
http://i.imgur.com/4kOfUl.jpg
http://i.imgur.com/nrnqDl.jpg
http://i.imgur.com/G7tqOl.jpg
http://i.imgur.com/LqCSyl.jpg
album
Looks very nice but its hard to get an idea of what it looks like a whole. An image of the whole pc would be ideal
@h20xide: what needs resizing?
@NFC: The first pic looks good to me. What case is that?
http://i.imgur.com/hhRsj.jpg
did a bit of cleaning the other day.
http://farm6.static.flickr.com/5061/...bc62e17c_b.jpg
http://farm6.static.flickr.com/5146/...126ae1b8_b.jpg
http://farm6.static.flickr.com/5187/...3421d6c0_b.jpg
http://farm6.static.flickr.com/5262/...7d2623d4_b.jpg
Only the side panel is left to work with...wish me luck with my first time with a dremel.
Love the drive cover, mav!
And Systemlord is correct. :up: Just make sure you return whatever Dremel you got if it wasnt the 4000 so you don't trade up hahaha. I started at the bottom and now I have four models. =P
hi guys
tomorrow i'll make the pics of my new rig
but now you can see the montage here
http://youtu.be/yu2qJEg7OxM
thx guys
