Originally Posted by
zlojack
Thanks, yeah. Watercooling with the CPU, NB and Mosfets in one loop on a PA120.2 and MCP655. Pretty good:up:
I would imagine the retailers will be flushing stock on the old stepping before the new one gets in. I imagine that they'll start to show up in the next month and a half.
For just the stock volts, you should be ok.
What are you using to measure temps? Try RealTemp and make sure your heatsink is mounted properly. What voltage are you using?
As for the multiplier, I'm not familiar with that board, but look around here, there should be a good thread about it.
