hard to say Athlon64OC. Not familiar with that stepping, but most all of the 06's are getting to 2600+ on air afaik.
I'm very sorry for you and I want you to know I'll think of you the next few day (if I was religious you would be in my praires).Quote:
Originally Posted by stone_cold_Jimi
I wish you a lot of strenght,
Jochenp
in order to update the list :
I also wish you a lot of strenght, and yes, i'm relegiousQuote:
Brechtvm LDBHE 0601 FPMW - cooled by ThermalTake Big Typhoon - 1.4250 (on DFI Ultra-D)
you forgot mhz?Quote:
Originally Posted by brechtvm
condolences, man....lost my father on Feb. 24th, and my Grandmother on April 4th. not a good year...prayers for you.
that being said, currently trying to oc a LDBHE 0604 CPMW on air.
will let you know.
dave
I finaly got my new mem (2x1gb g.skill extreme hz) to replace my dead ballistix :( and decided to take my 0601 for a spin.. solid at 2.55ghz on stock voltage 1.325 x 104% .. i'm going to play with my mem and see where I can take it.. it's a T chip (0601 fpmw) so I was told it would perform better under water but I havent completed purchasing my parts yet.. still running it in a p180 under a si-120 panaflo m1a 120mm fan.. idle 29c load 36c..Quote:
Originally Posted by Jester FPS
how high should I risk taking it up with some more voltage?
I think my cpu died :(
Stone_Cold_Jimi
Post #188 in the other x2 thread I had my LDBFE 0607 TPMW prime stable at 2.8 Ghz small FFTs 1.488v and custom blend 8 hrs primed 1.504v. Custom seemed to need a bit more juice
Kind of trivial info taking your news into account. My father is terminally ill with cancer, and I see my mum back in the UK very rarely. I feel for you man and my condolences.
RLM
Just changed my config to an Ultra-D from expert. Was quite optimistic of a better OC given that my x2 required less juice on my Asus premium than the expert. Exactly the bloody same though. Darn it!
Running Tmod 406 just for ref.
Can't believe I'm :banana::banana::banana::banana::banana:ing about 2.8 ghz. :D Envy and addiction.
RLM
Many many thanks for your condolences guys; my mum had been diagnosed with an inoperable brain tumour on 6th January and from then she basically partied as well as she was able until about four weeks ago, bless her. Most of the grieving happens as the symptoms worsen and the person you knew "disappears" or changes beyond recognition as suffering and anguish kick in, so the end is in many ways merciful.
My sympathy to those of you with ailing parents and relatives or recent family losses, I know that pain.
On with the show - I'll update the list later today and try to include any relevant info from other threads; I have to say, being given it all on a plate in one line is luxury brechtvm ;)
ok, for your enjoyment. learning some lessons from last time. :)
http://www.flickerdown.com/forsale/0...x245_thumb.JPG
Here's the link to the larger version: here
the A8N32-SLI overreports voltage.
thanks,
dave
Well, when I was priming last night my system locked up, upon reboot I got the dreaded 3 LED lights, looks like the CPU is dead, tried an overnight CMOS clear and that didn't seem to help...
i FINALLY found someone with the same stepping !Quote:
Originally Posted by ju1ce
is it alsa a LDBHE revision ?
LDBHE 0601 FPMW ?
hits here 2,6 Ghz @ 1,4vCore..
greatest problem = heat !
(need to cool it down..if i let it go above 50°, i get errors...)
is it possible to show me a picture of your cooling ? because i dont know 'bout which cooling you're speaking :s
sorry for your loss :(Quote:
To make updated the list easier for you:
lawrywild LDBHE 0602XPMW T 2.7ghz 1.55v (BIOS) under XP-90C
lawrywild LDBHE 0602XPMW T 2.6ghz 1.425v (BIOS) under XP-90C
are you being serious? if so, im really sorry to hear that... :(Quote:
stone cold Jimi you have my condolences on the loss of you're mother,my mother in law was diagnosed with a brain tumor in Aug/06. Thankfully she had an operation and radiation treatments and today is better than she has been the past couple of years!
I am recieving a 4200X2 LDBHE 0606BPMW "N" tomorrow,
would it be appropriate to post reults in this thread?
I was going to buy a 3800X2 however this 4200 was just too good of a deal to pass on!
Thanks for your thoughts mongo. Your new chip looks interesting, but it ain't a 3800! However, I'd love to see your results in the Official x2 OC thread - good luck with it.:DQuote:
Originally Posted by mongo
yep yep! i'm also quite happy to see someone else with the same cpu.. I searched all over locally for a decent stepping and found only 1 0601 and it was the fpmw which for the life of me i could find no refference to online. Since everyone said 0601s in general were decent I took the plunge and i'm much more impressed with it over my older toledo 3800+ x2..Quote:
I will take some pics today of my setup.. The temps are pretty high on this chip for just being stock voltage and a decent overclock.. my toledo needed like 1.5v to reach 2500mhz this one does better at 1.35 .. I would definately like to see it under water at 3ghz though :)
Dunska LDBHE 0606APMW N 2.66ghz 1.3v (BIOS) under TTBT
What is TTBT?Quote:
Originally Posted by Dunska
Thermaltake Big TyphoonQuote:
dave
update: LDBHE 0606 EPMW T chip 2800 @ 1.425 still on stock non-heatpipe hsf.
i got a x2 3800 0607 SPMW on the way, ive only seen 2 others with same stepping ...ill post results when i got it running. any comments on this stepping?
One of mine is LDBFE 0607 SPMW, currently running with a stock 4600+ HSF at 2700 / 1.392v. It actually bested my 4600 at 3GHz on phase by running 1.47v against 1.5v. Good luck, hope it's as good. :up:Quote:
Originally Posted by a5h
Jim my condolenses..may God bless you and your family....and thanks again for accumulating all the X2 OC data! Wish there was something similar with Optys!Quote:
