Sounds suspiciously like the temp that S7e9h3n was getting with auto cascade with similar combination of gases :) Maybe around that is the limitation before starting to really use some exotic gases with R14 being the final stage gas. Great result cold_ice!!! 200w load... that is one massive heat no processor should ever show off. (it's the load that i have burnt motherboards mosfets with shoving too much current through on some cases :P) It's amusing to see spark flying out of around cpu socket with smoke and fire actually starting on pcb...
