yup, almost identical to mine, under your Mach2 GT I'd say 3.10~3.20Ghz dual prime is almost guaranteed, just make sure your PSU supply enough juice for the insane clock :D :D let us know your result.Quote:
yup looks like your's clock about the same as mine so yea I'd say you're right on the money. normally a decent single stage phase change can boost anywhere from 150~300mhz, though it also depends heavily on the chip, I have had Six X2 dual cores in the past few months and they couldn't clock worth a crap, most of them hit the wall at 2.90Ghz!! only one 4200 crack 3.0Ghz @1.62v, but man do these opty clock like mad bat outta hell :D :DQuote:
Originally Posted by INFRNL
Edit: yea I'd took it up to 3.40Ghz already....hehe, check it out :D
Mine is about the same. I put mine back on a TT BT and was testing it last night. On air doing dual prime it is very hard to keep the PWMIC under 50c if I go aboveQuote:
Originally Posted by ben805
1.45v. Even with 2 120 fans in the area, it would still start going above. The cpu was at 47c. I used to think: why don't they just put a fan on it, but now I know it does always keep the temp below 50c.
hehe...tell me about the dang PWMIC, when I was running air I had 2 fans blowing directly onto that area but it's still 60'C+ during dual prime, was only using 1.42v :eek: now that I put it back on phase change, there's more room within the case for a big 120mm fan with 110cfm, during dual prime the PWMIC is around 45~48'C, I had already sink all the hotspot (R60 chips, etc)! the only way to drop it down to low 40s or high 30s is opened the window :DQuote:
Originally Posted by dogsx2
I've just recived a 0550UPMW opty 170. It does superpi at 2700Mhz 1.32V, 2800Mhz 1.42v, 2900Mhz 1.48v and haven't tried more. That's on a XP90C + Vantec tornado.
Here is a picture @ 2860Mhz spi 32MB 1.48v
http://img140.imageshack.us/img140/7...32mb3yd.th.jpg
And a SS at 3050Mhz 1.48v
http://img140.imageshack.us/img140/8...8vss6ow.th.jpg
It takes 47ºC full when doing spi32MB with "fresh" air.
finally got this chip stable at 2,9ghz... its way to time eating so ill settle with that.
@Magic, what did you have to do to get to 2.9ghz?
Also, to all of you guys, from your experiences, what is the best ram-type to use with these chips, UTT or TCCD?
I've seen UTT, TCCD, UCCC, Micron 5B-D / F, Infenion CE-5 / 6 all do very good. It doesn't really matter, atleast not with this stepping. Seems to have a solid memory controller.Quote:
Originally Posted by madgravity34
the mem ctrl sucks, so 1:1 isn't possible (for me with 1gb sticks) maybe 512mb tccd will clock high, but i think utt would be a better choice.Quote:
drive/data strength AUTO while running divider, or else my chip won't run divider at all, last a lot more vcore from 1,38v for 2,8ghz stable to 1,45v for 2,9ghz.
picked up an OEM 170 CCBWE 0550 UPMW from eBay. Haven't got any hardware to throw it in yet, but I hope it'll be a good clocker. Damn RD580 hurry up already.
I have problems getting above 2800 with mine :(
And need 1.500 to get to 2800 stable...above 2800 core0 is always failing on me...bad IHS mount?
Do you have the batch numbers for that cpu :)Quote:
Originally Posted by krampak
Thats what I was hoping to hear :D My Seasonic 600W PSU should be up to the job.Quote:
I set it up on my Mach II today on my A8N32 and forgot to reset the bios.
My old opteron 148 ran 300x11 and so the PC booted at 300x10 and worked fine lol :p:
The vcore dropped from 1.52v to 1.42v, but I think thats an issue with the A8N32 board which the overvolt option cures :)
Temps are higher than my 3300mhz 148 opteron at 1.52v. Under 2xCore load the CPU reads as low as -6c and idles at -17c is that OK for a mach II GT?
Cheers
mine should be here in a few days!
lol :p:Quote:
Originally Posted by -.-PhanTom-.-
Some people are never happy. .
"Dude you got a 2.8GHz multi-core!" >> :stick:<< "grumble woe is me"
this is my current bios setting w/ 2x1gig g.skill pc4000...
Genie BIOS Settings:
FSB Bus Frequency - 270
LDT/FSB Frequency Ration - 3x
CPU/FSB Frequency Ratio - 10x
PCI eXpress Frequency - 100Mhz
CPU VID StartUp Value - Auto
CPU VID Control - 1.450v
CPU VID Special Control - Auto
LDT Voltage Control - 1.20v
Chip Set Voltage Control - 1.50v
DRAM Voltage Control - 2.60v
DRAM Configuration Settings:
DRAM Frequency Set - 200 (DRAM/FSB:1/01)
Command Per Clock (CPC) - Enable
CAS Latency Control (Tcl) - 3.0 Bus Clocks
RAS# to CAS# delay (Trcd) - 04 Bus Clocks
Min RAS# active time (Tras) - 08 Bus Clocks
Row precharge time (Trp) - 04 Bus Clocks
Row Cycle time (Trc) - auto
Row refresh cyc time (Trfc) - auto
Row to Row delay (Trrd) - auto
Write recovery time (Twr) - auto
Write to Read delay (Twtr) - auto
Read to Write delay (Trwt) - auto
Refresh Period (Tref) - auto
Write CAS Latency (Twcl) - auto
DRAM Bank Interleave - Enabled
DQS Skew Control - Auto
DQS Skew Value - 0
DRAM Drive Strength - auto
DRAM Data Drive Strength - auto
Max Async Latency - auto
Read Preamble Time - auto
IdleCycle Limit - auto
Dynamic Counter - auto
R/W Queue Bypass - auto
Bypass Max - auto
32 Byte Granularity - auto
what all would you change to get higher overclock?
It was 4XX... don't remember it exactly.Quote:
these dual core are little heat generator, once you clock it up to 3.1~3.2Ghz you will more than likely see positive number like somewhere around 3~9'C underload.
Thanks for the info.Quote:
It seems my CPU is running cool for a dual core opteron then :D
1.48v at 310x10 and 2xPrime pushes it to -3c lol
I have to thank the guy that sold it to me. Off ebay no less :stick:
I did know the stepping was CCBWE 0550UPMW 408L though. I was however, unsure if it was an early or late batch. It seems the early 408L batches of this week and stepping may not clock so well according to a few posts here.
Although if I was the owner of one of them, I may reconsider my initial findings and re-test the CPU. Just to be 100% sure :p:
Cheers
Does anyone have a Opty 170 0550 UPMW (274L). Just got one from Monarch today. I can only get it stable to around 2.8Ghz and it doesnt matter what voltage I set it to. I got it to this clock @1.45v but even if I up it to 1.6V it doesnt go any higher. I am going to remove the IHS and replace thermal compound with AS5 and retest; I will also try running naked as well.
Monarch seems to still be shipping the 0550's; at least the one I just got is. Ill let you huys know what I end up with on this 274L batch.
INFRNL
Originally Posted by Grinch
anybody?
Same ram but different motherboard but it should give you some idea :)Quote:
System -- alpha0ne
Opteron 170 CCBWE 0546XPMW
10x280 2.8ghz @ 1.488Vcore / 1.51v Shown in Bios
DFI NF4 eXpert Bios NF4EDC07 / X850XT
2x1GB Gskill 4000 HZ 1:1 @ 280MHz 1T 2.67Vdimm / 2.71v Shown in Bios
2xHitachi 7K80 SATA II Raid 0 + 1xWD1600JB + 1xWD800JD
Memory Bandwidth (memtest 1.65) @ 280MHz = 2881MB/s
OS--- XP Pr0 SP2
VID= 1.475
VID SPECIAL= 102.4%
CHIPSET= 1.50v
LDT= 1.2v
LDT= 3
CPC = Enabled
CAS Latency(CL) = 3
RAS to CAS(Trcd) = 4
Min RAS# Active time(Tras) = 7
Row Precharge Time(Trp) = 4
Row Cycle Time(Trc) = 12
Row Refresh Cycle Time(Trfc) = 14
Row to Row Delay(Trrd) = 3
Write Recovery Time(Twr) = 2
Write to Read Delay(Twtr) = 2
Read to Write Delay(Trwt) = 3
Refresh Period (Tref) = 3684
Write CAS Latency(Twcl) = 1
DRAM Bank Interleave = Enabled
Skew = Auto
Skew Value = 0
DRAM Drive Strength = 7
DRAM Data Drive Strength = 1
DDRAM Response Time= Fast
Max Async Latency = 8
Read Preamble Time = 6
Idle Cycle Limit = 16
Dynamic Counter = Enabled
R/W Queue Bypass = 16
Bypass Max = 4
32 byte Granularity = Disabled
Just tried some cold air with my 170.
2950Mhz 1.52v (single spi1mb)
http://img163.imageshack.us/img163/9131/29507hp.th.jpg
And a SS at 3163Mhz, still on air.
http://valid.x86-secret.com/show_oc?id=73744
At 1.65V it didn't boot... I saw 45ºC in bios and when was charging the desktop it shutdown..
Hehehe, well, all is relative..of course I am happy with 2800, but seeing as other with similar chips can get 2800-3000 on air/water, I can help but feeling slightly disappointed with mine...Quote:
Originally Posted by Big.Wayne
Seems that even thought you get a good stepping/batch, a similar overclock is not guarenteed.... wondering if some of my other hardware is to blaim...
Anyways, upgrading my watercooling setup soon, so hoping to squeeze some more mhz out of my baby once that is set up :)
To be honest I'm in the same situation as you PhanTom. My 165 CCBWE 0551 UPWM won't do 2650 :( But now I think of it, thats more than a $1000 FX-60 so I'm gonna accept it and be VERY happy with it (and to be more honest, even if thats not the XS spirit) you don't notice the difference in any way apart from benching. Noone here can argue that they can see the difference between running FEAR at 70 or 74 FPS. Or Word opening in 0.7secs instead of 0.6 :D
