just don't try 4 x 1gig sticks as the board will spew them back at you.
R U telling the truth??? Have U tried 4xgig on Expert??? And what with DR (NoEx)???
will update my system specs in a few minutes. yes i have a expert, and i have tried 4GIG and it shows in bios as 3GIG, in windows under system properties it says 3gig. In CPU-Z it says 4GB. In bios i enabled MMIO memory hole and then i couldn't boot into windows but bios started to display the right amount. But no one on these forums know a fix. the SLI-DR older board does , well thats what i heard.Quote:
Originally Posted by Hirotaro
no, it's a windows limitation. use XP-64 for that much memory ;)
not in bios it isn'tQuote:
Originally Posted by ozzimark
it will show 4GB in bios.....it ain't in his case
Maybe New BIOS will fix it??
I'm sure DFI will resolve that (strange) problem.
I wonder if it happens with Every Brand???
I am using the new bios from TONY. This motherboard is not cutting the mustard.Quote:
I even set the ram divider to 166 to see if the problem was with ram. did some tests and 20 seconds after i boot into 32bit windows computer freezes. so i reformatted a hdd and tried a fresh install with 64BIT version of xp and 30 seconds into the install BSOD, also i lowered the timings on the ram. cheers.
I think the problem is with the new BIOS i flashed 2 days ago,.
Does any one have the original Expert BIOS. Cheers.
I had to enable MMIO memory hole to get it to show as 4 GB in bios but it crashes the computer.Quote:
Originally Posted by dinos22
Hello....anybody know :confused: does this mobo work with 4x512 1T?!
i am running 4GB at 1T, with beta bios 11/11/2005Quote:
Originally Posted by ranger1234
4x1gb at 1T? MY GOD! That's just nuts!
How far can you push it?
How far with just 2 x 1Gig, I have really had my eye on this HZ ram :)
What exactly are you needing 4gb for though?Quote:
Originally Posted by Tamille
my psu have not a 8-pin connecter,
can i use this 4-pin adapter + psu's 4-pin 12v connecter to be a 8-pin connecter ??
to plug into the LP Expert :)
My guess is that he bought 2 kits of 2x1gb to pick the best of the 2 kits. Then he probably figured... why not try both kits to see if 4gb can do 1T.Quote:
Originally Posted by J-Mag
Unless, he does some photoshop ownage. :D
Ok here is some tests i have done. The ram was bought for 2 computers and i thought what the hell tri 4x1gig 1t. here are my results so far.
SuperPI-32M stable - 1T 200mhz 3-4-4-8
http://img519.imageshack.us/img519/5...t32m0jr.th.jpg
Prime stable 2HOURS - stable 1T 200mhz 3-4-4-8
http://img519.imageshack.us/img519/8...ours9mc.th.jpg
SuperPI-1M stable - 1T 215.7mhz 3-4-4-8
http://img512.imageshack.us/img512/4...sp1m4id.th.jpg
SuperPI-1M stable - 1T 200mhz 3-3-3-8
http://img511.imageshack.us/img511/5...0mhz6dy.th.jpg
this is done on windows mediacenter edition 32BIT
Prime stable 7+HOURS - stable 1T 200mhz 3-3-3-8
http://img457.imageshack.us/img457/3...rime7yz.th.jpg
OPB> I have a friend with the EXPERT and he hears a strange noise from the board every few minutes and can not pin point it. Any ideas? You said if you hear a strange noise from the chipset area it's a bad board?
There is new BIOS release for Expert available onDFI's download section.
And there was one Beta Version (which supposed to improve memmory support) but they cut it from the server...
you sure about the temps there champ....mine seem a bit too low................can you double check them again pls against the old mobo...... :)Quote:
Originally Posted by Onepagebook
My results are a bit low....very very low in fact
Priming at stock 25C load temps .......idle 20C........don't forget i live in sydney......hence not exactly cold this time of year if you know what i mean
http://img499.imageshack.us/img499/6...ours2ba.th.jpg
here is the idle temp
http://img243.imageshack.us/img243/391/idle2ty.th.jpg
here it is priming at 2.6GHz 1.42V.....32C load ......can't be that low can it
http://img511.imageshack.us/img511/1...v33m7qj.th.jpg
No it cant be that low, unless your using ice water ;)
Thank you Buddy.Quote:
And Dinos, you're right, you temp is too low. :)
I've downloaded Beta Version (17) in ZIP file. (the exe seems not to exist on server)
well back to normal life,
Prob on the expert :
Is there anyone use 2gb(2x1gb set) Infaneon ce-6 or be-5 IC accidentally wil cause can't run dual channel?(Most likely it the dimm4 orange one closed to CPU socket)..
tried about 7 sets already.
But have U tried the Beta BIOS from 17.november??
Yes, and all the Infaneon sets can't work as dual channel.
