OK, here is the story. I tried and set the affinities with the task manager like you suggested. SP2000 still did not run the second test on mixed. I then tried SuperPi and got this error on the 2nd window: NOT CONVERGENT IN SQR05.Quote:
Originally Posted by QettoE
I then turned off all overclocks and ran on optimized defaults and got the same error. This was on the same memory that had no errors on Memtest x 10 hrs.
I googled this message and found it could be a memory issue, so I tried one stick of OCZ and then I reset the CMOS and tried a single stick of Corsair Value Select 3200 512MB in the far orange memory slot. Same DAMN error.
Do I have a bad core or am I doing something horribly wrong???? I want this to run so bad.
Please someone talk me from the ledge!!!!
