This test seems to be pretty useless. x2 3800 has a much higher maxcaseT and I can clock 250mhz higher.
you must only compare similar processors.
mine 170 0530tpmw has 53deg , want to see another results from the same week...
AMD64 TCaseMax - v1.16
CPU Information (CPU #1):
Standard CPUID: Family: F, Model: 3, Stepping: 2
Extended CPUID: Family: F, Model: 23, Stepping: 2
CPUID String: 20F32
Processor APIC: 0
Processor: Dual Core AMD Opteron 170 (Toledo)
CPU Speed: 2603.51 (260.35 x 10.0)
Revision: JH9-E6
Platform: Socket 939
Startup VCore: 1.350v
Maximum Case Temperature = 51C
TDP: 45.0 Watts
Written by: Arthur Liberman.
Idea by: Petr Koc.
More info at: http://www.thecoolest.zerobrains.com...topic.php?t=83
Why doesn't this programme work for me?
http://img378.imageshack.us/img378/3...x1165ro.th.jpg
http://www.xtremesystems.org/forums/...&postcount=377Quote:
Originally Posted by -.-PhanTom-.-
I get the same thing showing, but if when I hit copy to clipboard and paste it into a text doxument I find I have values for the Max Case Temp and TDP, 49c and 35w respectively on an Operton 175 CCBWE 0544XPMW, but there is something thereQuote:
How does this work exactly? Since my Cpu overclocks well, is that why I got low TDP? What does lower MaxTCase mean? That is has lower tolerance to heat? Also, would MaxTCase and TDP explain why my CPU hates volts over 1.45V?Quote:
Originally Posted by periquitos
Anyway, here's what I get:
CPUID String: 20F32
Processor APIC: 0
CPU Speed: 2830.02 (283.00 x 10.0)
Revision: JH9-E6
TDP: 45.0 Watts
Idea by: Petr Koc.
CPUID String: 20F32
Processor APIC: 0
Processor: AMD Athlon 64 X2 3800+ (Toledo)
CPU Speed: 2500.64 (250.06 x 10.0)
Revision: JH9-E6
Maximum Case Temperature = 65C
TDP: 71.9 Watts
Idea by: Petr Koc.
CPUID String: 20F32
Processor APIC: 0
CPU Speed: 2700.72 (270.07 x 10.0)
Revision: JH9-E6
Maximum Case Temperature = 49C
TDP: 35.0 Watts
One thing I haven't figured out yet is the following difference with a 4400x2.. as there are 2 versions available...
Processor AMD Athlon 64 X2 Dual-core
Model 4400+
Ordering P/N (Tray) ADV4400DAA6CD
Ordering P/N (PIB) ADA4400CDBOX
Operating Mode 32/64
Stepping E6
Frequency 2200Mhz
HT Speed 2000
Voltage 1.35-1.40 V
Max Temp 71°C
Thermal Power 89W
L1 Cache 128KB
L2 Cache 1MB x2
CMOS Technology 90nm SOI
Socket Socket 939
and....
Model 4400+
Ordering P/N (Tray) ADA4400DAA6CD
Stepping E6
Frequency 2200Mhz
HT Speed 2000
Voltage 1.35-1.40 V
Max Temp 65°C
Thermal Power 110W
L1 Cache 128KB + 128KB
L2 Cache 1MB x2
Socket Socket 939
How do I know which version I have... and does the program now which CPU is which..?
Also.. even if I have the 110W thermal power version which is rated at TMax 65C... how come mine can only handle 55C according to the program...?
10C difference is a lot.. especially for a $550 chip..
NC™
Standard CPUID: Family: F, Model: F, Stepping: 0
Extended CPUID: Family: F, Model: 2F, Stepping: 0
CPUID String: 20FF0
Processor APIC: 0
Processor: AMD Athlon 64 3200+ (Venice)
CPU Speed: 2009.25 (200.92 x 10.0)
Revision: DH8-E3
Startup VCore: 1.400v
TDP: 67.0 Watts
Idea by: Petr Koc.
Opteron 148 CABYE 0543FPMW
Standard CPUID: Family: F, Model: 7, Stepping: 1
Extended CPUID: Family: F, Model: 27, Stepping: 1
CPUID String: 20F71
Processor APIC: 0
Processor: AMD Opteron 148 (San Diego)
CPU Speed: 2883.74 (320.42 x 9.0)
Revision: SH8-E4
Maximum Case Temperature = 63C
TDP: 61.8 Watts
With my chip overlocked to 2650mhz, i get this is the AMD64 TCaseMax v1.18:
TMaxCase: 49C
TDP: 35W
Ok, what exactly do the TCaseMax and TDP mean there? The rated wattage of my chip is supposed to be 110W, so what do those values above represent in relation to actual output wattage?!
I am interessted in how this programm works...Quote:
Originally Posted by The Coolest
I searched the amd tech docs for a way to read tcase max using the cpuid call (are you using it?) ut could'nt find anything
found it in the BIOS and kernel developer guide
AMD64 TCaseMax - v1.18
CPUID String: 20F32
Processor APIC: 0
CPU Speed: 2800.72 (280.07 x 10.0)
Revision: JH9-E6
TDP: 35.0 Watts
Idea by: Petr Koc.
Hey Hassan I've got the same data as you with a 165, but I can't get to 2800. Is that stable? Here's mine:
CPUID String: 20F32
Processor APIC: 0
Processor: Dual Core AMD Opteron 165 (Toledo)
CPU Speed: 2700.10 (300.01 x 9.0)
Revision: JH9-E6
TDP: 35.0 Watts
Idea by: Petr Koc.
I have a 170 CCBWE 0546XPMW that is stable at 2700 with 1.46volts... so far I'm priming at 2800 @ 1.6volts for 2 and a half hours and still going my max load temp is 38C with water... I'll tell you for sure in the morning
Hang in there Hassan, that week 170 (see my sig) are good for at least 2.9GHz 100% torture stable with less than 1.6Vcore after burn-in :toast:
My Tcase max is 65C. When we reach the max of this temp does the Tcase melt? if we take the Heat spreader off does this increase the temp in witch the CPU can survive at because it has no heat spreader?Quote:
Standard CPUID: Family: F, Model: B, Stepping: 1
Extended CPUID: Family: F, Model: 2B, Stepping: 1
CPUID String: 20FB1
Processor APIC: 0
Processor: AMD Athlon 64 X2 3800+ (Manchester)
CPU Speed: 3000.73 (300.07 x 10.0)
Revision: BH9-E4
TDP: 65.6 Watts
Idea by: Petr Koc.
CPUID String: 20F71
Processor APIC: 0
Processor: AMD Opteron 146 (San Diego)
CPU Speed: 1000.04 (200.01 x 5.0)
Revision: SH8-E4
Maximum Case Temperature = 55C
TDP: 38.2 Watts
Idea by: Petr Koc.
Well, surely its not the temp where the Tcase melts. Mine is 49c and the proc has been at 53c in SmartGuardian, so...Quote:
Originally Posted by Serge84
But maybe thats the temp where the proc starts to error? Makes sense, mine stops priming when ~50
AMD64 TCaseMax - v1.17
CPUID String: 20F32
Processor APIC: 0
CPU Speed: 2500.81 (250.08 x 10.0)
Revision: JH9-E6
TDP: 35.0 Watts
Idea by: Petr Koc.
And here's mine:
http://img56.imageshack.us/img56/5100/tmaxcase0xt.jpg
Edit: Pic of never version of TCaseMax.
Hi. This is my 3200+ Manchester running undervolted at 2.5ghz: :banana:
Standard CPUID: Family: F, Model: F, Stepping: 2
Extended CPUID: Family: F, Model: 3F, Stepping: 2
CPUID String: 30FF2
Processor APIC: 0
Processor: AMD Athlon 64 3200+ (Manchester)
CPU Speed: 2500.00 (250.00 x 10.0)
Revision: BH9-E4
TDP: 67.0 Watts
