I gave you the easy answer.:)
Ok, now you answer to this.Quote:
Originally Posted by Zebo
Why Intel stats are increasing without it having a network but AMD's don't ??
http://www.tomshardware.com/stresstest/intel.html
Originally Posted by Hans.Gruber
That's easy too. Toms HW a liar making this whole test up after initial failures.
Intel used to have a network.
I got all this archived...(need IE)
http://www.csc.calpoly.edu/~smanning/44.mht
Lol, he's right. I just verified it and Intel says no net, but it's stats continue going up. If I was Intel I'd be pissed off that my puppets were making it look like I needed them more than I actually did.
Edit: I honestly think this has got to be a joke. There is no way someone could &(*^ up a test so badly, try to cheat in it so badly, and then cover it up so poorly. And if it turns out this is a joke, I'm sure it'll infuriate Intel that a site that gets as much traffic as Tom's makes them look so bad.
I wonder what Mr. Pabst thinks if he's reading this, gurus and legends and such cutting him up good lol
:wierd: :bounces:
Probably too busy trying to scrub the stink of whoredom off himself to be reading this.
nvm
Yeah was posted on page 5 I think. Sorry.
Guys lets stay calm and not have this turn into the flamewar that it is moving towards.
Yeah lets get back on track to the burning issue - namely THG's shenanigans.
He claims not to be touching priority selection in Windows for AMD but how can he explain the following:
Approx 3:20pm my time (+8 GMT) the readings were as follows:
Lame Encoder Intel = 301 AMD = 256
Winrar Intel = 1634 AMD = 2072
Farcry Intel = 27FPS AMD = 35FPS
Divx Intel = 1380 minutes AMD = 80 minutes
About 10 minutes later the following:
Lame Encoder Intel = 303 AMD jumps up to 311!!!
Winrar Intel = 1643 AMD jumps to 2321!!!
FarCry Intel = 27FPS AMD drops to 15FPS!!! (edit: latest now is Intel at 37 and AMD at 35!)
Divx Intel = 1390 AMD jumps to 130
No explanation for the Farcry drop other than priority adjustment is there?
i think their benchmark numbers are TOTALY fubared. there is no ryhme or reason to them. at some points it shows intel doing better in one area and then a few hours later it shows amd doing better.. they are totaly useless sets of data imo..
I am looking forward to seeing what kind of rational conclusions they are going to come up at the end of this!
If it were me, I would be saying "well basically we f###ed this test up big time - sorry!"
lol, i think they shoulda used a dbl bar graph for the far cry section, one bar showing the amount of runs, one bar showing the fps, cuz the fps is kina misleading, like when the bar shows intel winning, ppl are like ooh yay, but they forget to read amd has been faster for more time, making it finish 300 more runs than intel
oh ya, lithan, u get my pm :)
charles, i think you might have received a very early idea of btx, probably just an atx heatsink with a shroud to suck cool air from outside of the case. it must have been very very early because they changed the btx idea and went fopr a different mainboard design and a tunnel copu heatsink that pushes the air through it from one side to another:Quote:
Originally Posted by FUGGER
http://pcstats.com/articleview.cfm?a...id=1712&page=2
this is from january 2005 and shows and early btx heatsink sample, wich looks identical to the final version of the btx heatsink that is now available in retail. somebody posted a pic of it earlier in this thread:
http://www.watch.impress.co.jp/akiba...btxp4560j.html
and btx mainboards have a totally different layout than atx mainboards, a real btx heatsink will just not fit in an atx mainboard.
left is atx right is a btx mainboard
http://img226.echo.cx/img226/7051/btx12mz.jpg
here you see what the idea of btx is. on the left is an atx case, theres acase fan in front of the hdds that blows in fresh air on the bottom, and a psu fan on the top that sucks tha air out. then you have a fan on the videocard and cpu and most of the times also on the northbridge. but each of those fans is not moving the air from the intake to the outtake of the case but only moving it around creating turbulences and heatink up the case air.
on the right you see a btx case, there are only 2 fans, one that takes the air in at the front and one that takes it out on the back. maybe an extra fan for the videocard, but thats it, there is only one direction the air is moving, from the front to the back.
http://img226.echo.cx/img226/6513/btx29fa.jpg
thats why i dont think the heatsink is a btx heatsink, btx heatsinks dont have a fan on top of them, the idea of btx is to move the air from right to left, a fan on top would only create turbulences and reduce the cooling effect. and the heatsink isnt shaped like a btx heatsink either taking advanctage of the airflow from right to left.
i think your heatsink and shround are intels first steps towards btx but dont have anything to do with the current btx standard.
they probably sent you an atx heatsink with a shroud, wich is how the idea to btx started. thats probably why it is a btx heatsink, but then again its not. :D
so your saying the idea of having one airflow to cool the cpu nb sb memory and videocard are now changed? the idea of btw WAS to have one wind tunnel to cool all hot parts of the pc. and intels btx site still says so:Quote:
http://www.intel.com/cd/channel/rese.../eng/95347.htm
andQuote:
Superior Thermal Environment
*High power components use the same in-line, high velocity, low temperature airflow
*Above and below motherboard airflow helps improve voltage regulation and socket capability
Superior Acoustic Performance
*Only two fans required - even in high performance configurations
-Thermal module fan and PSU fan create and manage simplified system airflow
*Lower impedance and high velocity, low temperature air allows lower fan speeds
http://www.intel.com/cd/channel/rese...hermal_Modules
so that explains the btx design as having a duct on the FRONT of the case sucking in air ,blowing it over the cpu and then exhausting it in the rear.Quote:
BTX-based Motherboards
The BTX-based motherboard layout differs significantly from ATX/microATX, and requires designs built specifically for BTX. BTX also allows for multiple board sizes utilizing a common core:
picoBTX: maximum width 203.20 mm, up to 1 add-in card slot.
microBTX: maximum width 264.16 mm, up to 4 add-in card slots
BTX: maximum width 325.12 mm, up to 7 add-in card slots
BTX-based Chassis
Because of the changes in motherboard layout, the new form factor will require unique chassis designed specifically for BTX. It will be critical to select a chassis that supports the chosen board size. A BTX-compatible chassis will require built-in features to attach the Support and Retention Module (defined below). Additionally, a Thermal Module Interface may be required. This is a ducting feature connecting the front of the Thermal Module to a front vent. It is needed to ensure that airflow exiting the Thermal Module cannot re-circulate and re-enter the Thermal Module Interface opening.
Support and Retention Module (SRM)
The SRM is a metal plate that is assembled to the chassis beneath the motherboard to provide structural support for the motherboard and retention for the thermal module. The SRM is expected to be shipped with BTX-compatible chassis.
the case also needs to support this.
your case and duct are on the SIDE of the case, not in the front.
so either you got an early btx design before the standard was set or intel changed the btx standard and hasnt updates their site yet?
and i cant believe that intel went from the btx with a windtunnel to a simpler btx with just a duct from the side of the case. this simple duct from the side of the case doesnt have all the benefits intel advertised btx with, bigger and heavvier heatsinks possible and cooling all system components. the duct you use only cools the cpu.
and your mainboard is not btx, so did intel scrap the whole idea of btx mainboard layouts? :confused:
this doesnt make any sence, i think you have a very early btx prototype.
if it requires a btx case to work then why doesnt intel say anything about it?Quote:
Originally Posted by Noldor
while this might be an error of communication, the following certainly isnt:
all dual core reviews were done on mainboards intel sent the hardware sites. they sent not just dual core cpus but testing systems, some sites even received an entire case already assembled to test the dual cores and it also had the same heatsink on it!
dual core cpus dont need a btx mainboard to run, what they need is a better heatsink! theres no need for a new case with shroud and whatnot, all you need is a better heatsink!
no amd vs intel discussion please :D :toast:Quote:
i dont understand why intel wants to save 5$ on each cpu wich a better heatsink would cost them at most... i hope they finally start equipping their boxed cpus with better heatsinks.
there are intended to be used on atx mainboards and atx cases, and they dont need a btx mainboard and case tow rok, they only need a good heatsink.Quote:
exactly! :toast:Quote:
please stop the intel vs amd discussion, this thread is about thgs incapability of getting a cpu stable, what brand that cpu is doesnt really matter, id laugh my 4ss of as well if it was an amd cpu they wouldnt manage to get stable and kills 5 mainboards trying to get the system working :lol:
Lithan and everybody else, please stop the amd vs intel discussion!
im going to remove all intel vs amd comments and posts to keep this thread clean. if you want to start an intel vs amd thread please do so in the chat section.
tom got frustrated and got drunk and then fell on the server :lol:Quote:
Originally Posted by saaya
Super Saaya to the rescue! :p: Glad you cleared up that mess.
LOL super saaya yin :lol:
*looks in mirror* meh, still no blond hair
gotta try harder.... hrrrnnngggmmmm
bah i give up...
btw, i compared the performence stats at 4pm and 6pm central european time:
340 cds
342 cds
1844 archives
2576 archives
37fps 1152runs
35fps 1450runs
1550 mins
130 mins
2 hours later:
351 cds
351 cds
1906 archives
2655 archives
37fps 1198 runs
35fps 1495 runs
1600 mins
140 mins
this means the intel system performs as following:
it encodes ~5.5cds/hour
zips 31 archives/hour
does 23 runs of far cry/hour
encodes 25mins of a dvd/hour
and the amd system performs as following:
it encodes ~4.5cds/hour
zips 39.5 archives/hour
does 22.5 runs of far cry/hour
encodes 5mins of a dvd/hour
lets see if this will change in future.
does anybody have several screesnshots of the same day at different times to compare how the systems performed before?
Nah, a decent copper heatsink would cost $10-15 more to make I figure. A better aluminum heatsink would mean more noise (since cpu manufacturers are hardly free to create high performance sinks, limited by the need for 100% compatibility and little R&D).
Trance, I got it. The only thing I can figure is now that memory controller is onboard, games might stress it more than most cpu loaders do and it might be the reason your games heat up the cpu more than cpu loaders. I'm not exactly sure how much heat output A64 mem controllers have.
This thread was flying yesterday :D
I dont make any $ from Intel directly LOE. I stand by the product that serves me well. Others stand behind AMD
Anyway, it will interesting to see where the stress test goes on THG. :lol:
yeah! i hope they blow up some more mainboards, a psu and maybe some other stuff :lol:
this is really fun to watch :rofl:
i hope epox gigabyte and intel will send them their special "thanks" and support thg with the hardware they "deserve" in future :D
if i was in charge at intel id send them network cards to test to see if they are capable of doing a good review of that before i send them anything complex again. i bet they would kill 2 boards with that network card as well though :rotf:
man i was close to laughing tears when i first read the thg article updates about all the boards they killed :D
saaya, the link
of the six pics on the right, u can see the middle left one shows an actual btx design, the fan is on the side, so it is btx, reviewers just must not have been informed that they need to keep the fan on the side
i guess most the review sites pulled a tom, and took the shroud off, and mounted a fan on top, like they are used to doing, and didnt do what intel wanted them to
THG with a network card:
It seems the heatsink on the NIC was not large enough and it overheated frying the memory power regulators on the mainboard. We tried a second motherboard and found the southbridge to be faulty which caused more fialures. We finally resolved the problem by installing a XP-120 with a 220CFM delta fan on the NIC. Currently this setup is working nicely with the fan being powered off of the mainboard.
:rolleyes:
Originally Posted by MaxxxRacer
GAWD what a bunch of liars... How the heck you install an XP120 *AND* a 220CFM fan on a nic !??!?! I gotta see this before believing.
220 CFM means a huge denki or panaflo 120x38mm. XP120 masses about 1 Kg or two pounds. Nic's have no holes in them to "attach" anything. You drill holes and PCB is fried.
lol it was a joke :ROTF:Quote:
