Doesn't support newer boards now, the author stopped further development. You could try systool instead.
EDIT: looks like i was wrong :p:
Thank you :toast:Quote:
Originally Posted by TEDY
2906MHz 1.5Vcore ST2004 stable for +1h, CPU -12ºC under Small FFTs stress.
Hmm, I think this CPU is more stable now with 5.10-2 BIOS :toast:
so i should change my 5/10-3 bios for -2 ?
i have bh-5 pc3500 twinmos
Give 5.10-2 a try :banana:Quote:
Yep better change it.Quote:
I can do 262MHZ(BH5) single chan with the 510-2 bios on 3.18V.
Unfortunely my other stick does barely 243MHZ single chan :(. (orange slots)
http://www.benchmarkhq.ru/english.html?/be_cpu.html
For cpu tools :)
CBBLE 0512 DBPW
found S&M , it does really stress CPU to max......anyone knows how to loop it ??
Really don't know and i would be glad if someone knew because then i can throw the other 4 stress test in my recycle bin :DQuote:
I ran some superpi and it went great ;)
http://www.ocxtreme.org/forumenus/at...tachmentid=110
Nice :)Quote:
Originally Posted by NiCKE^
3006MHz 1.5V stable now for 22min SP2004 :stick:
Sounds very good Dani!
Measure for yourself and get the truth.Quote:
Check it w/ a DMM - find out what it REALLY is :fact: (Prolly better than you think). If not at least you know for sure.
Smartguardian usually reports my 12V as 11.77. MBM shows 12.05 and so does my DMM :)
3GHz under StressPrime2004 full load:
Smartguardian: 12.16V
MBM5: 12.47V
DMM: 12.47V
My rails are always under what they should be, wonder why...
Play'd some more with superpi now and got better results :D
NiCKE^: I'm guessing your "OCZ 520W" is a Modstream? If not just fix the rails ;)
0517BPDW 3004MHz 1.5V :D
http://koti.mbnet.fi/dani69/DFI%20nF...re%201h11m.gif
Yepp it's a modstream.Quote:
Originally Posted by exscape
Love my Powerstream :) A voltmeter is light years better than any motherboard sensor. According to SmartGuardian the 12V is now 11,83V - according to the voltmeter its 12,03 under load :)Quote:
Yeah mine is also over 12v with a multimeter ;)
0516 CPBW is very bad ,is it max????? :soap:
http://wowgame.free.fr/3000+%20939/L...AW%20decap.jpg
for the moment prime 1.504v 2906Mhz full load 32°C :banana:
before IHS removed prime 1.52v same speed 43-44°C full load :D and can't pass over 2H30 at 1.504v...
I hope no one minds I have copied the database over to ExtremeOverclockers and encouraged someone with time to go through their Venice overclock thread to complie more data.
