should have used msec modded pi and removed car low tests since they can vary 30+fps.
I agree though, low latency is very good... the problem is running "high" vdimm ;)
bored so i broke my own tccd record. best i can do with these sticks
http://members.cox.net/italygirl25/tccd%20325.bmp
3.5 is safe for 24/7 use at least on my sticks it is had them for a year ran them for 6 months straight at that voltage before.Quote:
Originally Posted by STEvil
i'm not worried about the ram, just the CPU.
about 3.1v is all I trust it to for 24/7 ;)
make it stop....make it stop.....325MHz 1:1 OMG you are a legend :slobber: :woot:
Originally Posted by chew*
gracie astaris
WE NEED 150 DIVIDER....Tictac pls keep that in mind if you are going to do a modded bios
Originally Posted by astaris
I try. although i'm no opp or opb or macki. wish i had the money to blow that those guys do though. So far i've really havent come across a good cpu. Let me get a good cpu or wait till summer when chilly builds my phase unit and then ill really show you what i can do.Quote:
Originally Posted by dinos22
I might add i have had a broad experience with abit boards and also a headstart ahead of most of you with my fatality so i know what the board likes and doesn't like. this board seems to have all the same quirks that my fatality had so it's easy for me to get around it. There is a thread somewhere on the forum about it. basically this board is exactly what i asked abit to make based on issues i had with my original fatality an8. whether or not they actually listened to me is a mystery though. all i know is i got what i asked for.
tictac can you do me a favor and rip apart the an8 ultra bios and the fatality an8 bios. the damn board is identical so i see no reason why it cant support the higher voltages they all use the same chips even the sli board i have uses same chips..........unless the uguru chip has its own bios? or programming if so then how would i program it with the an8 ultra info. If i can get it to work i won't have to buy an an8 ultra also as for phase isnt gonna be good on this board with that cmos battery so close.
your cpu is better than mine.. best I can manage is about 315 with my 2x512 of TCC5 ;)
heh thats bench stable only best i can do 110% stable is 2.4 gig prime stable for months and thats at 240fsb at 300 fsb i get prime crashes random sometimes in 1 hour sometimes in 6 hours sometimes in 36 hours. To further determine it was cpu i used dividers running memory at lower speeds and still failed prime. i think its or hope its heat related though. this claw just generates alot of heat Ocing with air is out of the question with this one.Quote:
I know the memory is stable cuz i can loop memtest for days no errors so its got to be the cpu. did the same thing on 3 boards so far. and my 2 previous winnies even a cbbhd couldnt break 2.4 prime stable so far.
anything over 250 fsb = prime errors and anything over 2.4 gig also = prime errors. hopefully eventually ill stumble on a good cpu so far im 3 for 3 now
And yes I know prime isnt the god of all tests but I'm a pro alpha league gamer and cant afford to have any errors and or crashes while I am in a match even though i have never experienced one at 2.6gig. If prime fails than its not stable enough for me
same sort of thing with OCAU and i4memory guys in Australia...most people use water cooling for them here
i just found out we have a distrubutor for Gskill ram....sweet stuff.....i noticed they have PC4800 ram for AUD$350 inc.local taxes (~USD$260) never before was it remotely close to this....there's gonna be a lot more TCCD guys here now...besides corsair which doesn't reach gskill levels
0444 3000+ cbbhd for me, doing 2630 @ 1.61v so far. 2650 made it through a pi32m run once, and I havent been able to do it again..
neo2 though, so not really appicable to this thread ;)
3.2V on TCCD? :slapass:Quote:
nice clock... :woot:
yah f1 la models week 440 tend to like voltage i wouldnt dare try it with week 437 or le modules though they definitely don't like voltage.Quote:
Originally Posted by tictac
All AN8 series using same bios. uGuru Rom identified the board and decide which board can have 3.55V max & 2.8V max.Quote:
Unfortunately this uGuru rom is encrypted by Abit... so no way i can dissambled/mod it.... sorry :(
so an8 ultra doesn't have 3.55vdimm?Quote:
:slap: ... nah... he refering to AN8 Fatal1ty non sli.... he need more than 2.8bv on that board
Refer to 1st post of this thread for Vdimm info
ABIT's BACK!!!
Thanks for info Tictac wonderful thread everyone.
AN8 Ultra $136 in USA at atacom
http://www.atacom.com/program/print_...T6&USER_ID=www
great avatar......(not as good as mine) BUT i like it a lot:slobber:
Originally Posted by Zebo
Its nice to have another good alternative to the DFI boards. Maybe not as good but definetly good.Quote:
Im still waiting for zipzoomfly or newegg to carry it, im just really leary of some etailers.
Well i have 4 boards here on test for reviews. 1 of them is the DFI SLI-DR and the other 1 is the ABIT AN8 Fatal1ty SLI and i can tell you that for stability the ABIT wins hands down....for board features the ABIT wins hands down......for bios options the ABIT bios is stable and is currently being worked on to include a number of options to the end user. I cant say much more about what if any options will be included because im under NDA....lets just say watch this space.... ;)Quote:
Originally Posted by Delirious
The DFI is a great board....however from the technical test i have been carrying out, the DFI just LOST its place at the top. ABIT now takes its place.
The board responds much faster, is more stable....oh hang on i allready said that :woot: and to top it all packs some neat groovy bling red LED's on the MOBO MOFO.
ok so i lied my tccd had a little more left in it i forgot i was running tight timings so i loosened them up a tad and got this. The board and memory is 100% stable the cpu however as ive stated before is stable in everything except prime. ran prime for 3 hours then crashed.
http://members.cox.net/italygirl25/tccd%20330.bmp
I might just order a gig kit of mushkin redline xp4000 as i found out my friends redline isnt 4000 speed rating. unfortunately i cant get it in 2x256 mb packaging seems to be available in 2x512mb sticks only :/ but for $200 its less than gskill.
thought i might just add this tidbit of info for the rest of you. My bios is 13 that i received with this board and i have no issues so im not about to change it with the scores im putting up.
chew*... get some decent cooling & VGA card
3stage cascade + x850xtPE + FX55 + XP4000
break some 3dmark2001se record ;)
Ok let us know when the new alpha bios will be available :)Quote:
Originally Posted by topboy
Thanks again. :D
