You should be able to accurately calculate any revision E Turion wattage using the
Benchtest CPU calc, because Turion has a very defined thermal limit, and is not as open ended as desktop models. Just plug in max speed for the 25w line (2200MHz), voltage (1.2), and wattage (25w) as the known variables, then calculate your unknowns. To verify the accuracy of the calculator, I plugged in 2400MHz and 1.35v (which is the highest 35w Turion) and sure enough wattage came out to 34.52w, so I'd say the calculator is pretty reliable.
