prime not pass :D, memtest pass and i can play game in hours...
:toast:Quote:
To contribute please do the following:
* Set timings to 1T-2-2-2 (I run 1T-2-2-2-8-7-15, but that is just for reference)
* Find the max MEMTEST STABLE MHz at 3.1v, 3.2v, 3.3v, 3.4v, 3.5v, 3.6v.
* MEMTEST STABLE (for this thread) = 25+ loops of test #5
* Where possible... also give chip dates & PCB revision.
I got two sets of Speed Premiums, set one likes TheVolt alot. Set two not so much.
Set one: 250Mhz x10 1T 8,2,2,2,2.0 @ 3.5V memtest/3D stable (games for hours no issues) StressPrime stable @ 245Mhz.
3.0V needs 8,3,3,2.0 @ 205Mhz, 3.1V 8,2,2,2.0 to 215Mhz, 3.25V 8,2,2,2 @ 230Mhz, so the volt scaling is steep on this set. Also ONE stick likes DIMM1 rather than DIMM3. this plays into the fact the SP's aren't matched sets.
Set two: 245Mhz x 10 etc, etc, EXCEPT. With this set I get occasional system reboots, even if I down clock to 235 220 210. Passes memtest, 3D stable 245Mhz, StressPrime for hours 240mhz but gaming I get occasional reboots regardless of speed of timings. But so intermittent its tough to figure out much beyond it IS this set of ram doing it. Further burnin/testing to follow.
I sent back the RMA, hope the TMII is still out of stock when it arrives, Ill ask to switch to 2x SP sticks instead for added $. ($1 ;-)
Goal now, switch to water cooling and hope the Vcore circuit can supply the juice for 250x11. The CPU can definitely handle it, it actually runs 250x10.5 for 2625Mhz just fine on Air for anything short of StressPrime.
hey RAB* shoot me an email when you on i got somethin for ya bro:D
Twinmos
05064
Tmd7608f8e44b
1a4t
3.0V 240 2-2-2-8 25loops #5 ok
3.1 and 3.2 doesnt help 250 2-2-2-8 #5 errors
has to be a board issue TEDY! :(
i'm thinking on changing for 64bits aswell... as i can't take real advantage of my sticks either... :(
board ?
3.3v 250 2-2-2-8 #5 25 loops OK
3.3v 255 2-2-2-8 #5 errors BURN IN here ?
3.4v 260 2-2-2-8 #5 28 errors in 4 pass then i stopped
3.5v 260 2-2-2-8 #5 few errors
What irritates me is that 1A4T runs well 240 on just 3.0v and later drops....
I'm pressuming this stick ( 3 more to test ) is capable doing around 270 with 3.6-3.7v but i'm affraid to put so much juice. Afterall i did burn my KHX3200/256 while pumping them 3.7-3.8 at 270 2-2-2-x...LOL
Any suggestions ??
after some "burning in" here're results:
3.0v 240 2-2-2-8 25loops #5 ok
3.1v 245 2-2-2-8 250loops #5 ok
3.2v 250 2-2-2-8 30loops #5 ok
at 3.3v 255 ain't stable, it resets lol....will do more burning later.
Hi all, can the user of UTT on intel motherboard give more information about timings and parameters to set ? i test my 0503 AA4T 44D for hours but i can't do better than 210@ 3.2V 2/2/2/5 ...
lol TEDY, u used to have DFI nF2 didn't u? i thought u were on it... not on nF4! :p
my VX does 240 at 3.2 and 250 at 3.4 5-2-2-2
is it 3200 or 4000
Value VX 3200
2nd module
3.3v 253 2-2-2-8 25loops #5 ok
3.4v 257 2-2-2-8 25loops #5 ok
3.5v 260 2-2-2-8 25loops #5 ok
this 1A4T rocks at low voltage...it runs 200 2-2-2-8 at 2.5v :P
Nice memory you have there Teddy :toast:
Be interesting to see what you get with DC setup. Thanks for the info :D
thanks
3rd module does even a little better
3.1v 246 2-2-2-8 250loops #5 ok
3.2v 251 2-2-2-8 30loops #5 ok
3.3v 254 2-2-2-8 25loops #5 ok
3.4v 258 2-2-2-8 25loops #5 ok
3.5v 262 2-2-2-8 25loops #5 ok
3.6v 265 2-2-2-8 50loops #5 ok
gonna try 270 at 3.7, is it safe ?
i have 120mm with zalman bracket over fan at full speed ....
I noticed it makes difference in terms of stability when vent spining at full or low speed....hehe
Nice stuff then... :up:Quote:
Originally Posted by xxORBxx
PS. Rabbi, any chance you could get the pics in the first post to work again? I went to print this thread yesterday but saw that they were red x's. You could host them at www.imageshack.us if you need a host. :up:
uwackme and TEDY, I have updated your results... thanks for the input :toast:
TEDY, yours is the first NEW-BH5 entry :D
isp, only one pic is not working and esdee will have to resend it cos I dont have that one on my PC
Is that the new OCZ BH mentioned in the other thread? That looks like some good stuff.Quote:
Originally Posted by Rabbi_NZ
No, it's the TwinMOS with 1A4T prod code... as opposed to AA4T which comes with the NEW-CH/UTT die
If I haven't mentioned it before, congrats on the moderatorship bro! :toast:
I'm still testing my VX...
They can close SPi 1 mb @275 3.9V :D
They are memtest stable at:
3.1v 245
3.2v 252
I'm testing the other voltages...
and in wrong AMD 462 section :p:Quote:
aaah ohh too much of this :toast: for Rabb... I'll get to fixing itQuote:
Originally Posted by TEDY
http://users.skynet.be/pt1t/utt260.PNG
Hi ,
Here Twinmos SP do 260mhz 2-2-2-5 @ 3.3v .
Thanks Pt1t :)
please do this:
